How to avoid overlap of ports with org.eclipse.elk.layered algorithm? [message #1803958] |
Thu, 14 March 2019 05:47  |
I have several ports on a node and I want that they are distributed on all borders and not only on one side. I don't find the right configuration. Can you help me?
I use the last version of ELK (master branch).
Steps to reproduce:
* The original graph is like in "Initial graph.png"
* Open "PortsSample.elkg" in the "Layout Graph" view
* The result of the layout is like in "Graph after layout.png": all the ports have WEST as fixed side and are distributed on this side, with overlap. Even if there is org.eclipse.elk.spacing.portPort set to 20.
The problem is the same if there are edges (for example with "Diagram with ports and edges.elkg").
I tried several configuration but without success.
Laurent
FUDForum. Page generated in 0.09890 seconds
