Home » Modeling » TMF (Xtext) » Grammar Problem
Grammar Problem [message #1803745] Fri, 08 March 2019 03:38 Go to next message
I'm having a problem writing my grammar.
What I'm trying to do is create a grammar that allows me to do this:
import things
from otherThings import potatoes
import bananas
import apples as ap
use :
       filex
       filey
import moreThings
But I can't do this. "use" if appear in the document, should appear only once, and I should be able to make "import" in the hole document.
Can you help me?
[Updated on: Fri, 08 March 2019 03:38] by Moderator
Re: Grammar Problem [message #1803746 is a reply to message #1803745] Fri, 08 March 2019 04:50 Go to previous messageGo to next message
You appear to have three regions
pre-amble - import ...
body - use ...
post-amble - import ...
so write a grammar that sequences the three regions with their distinctive content.
(Free form grammars are harder to write and often have poor error diagnostics / completion assist; you will find it much easier if you have distinctive terminators such as ";" and sub-clauses such as "{" ... "}")
Ed Willink
Re: Grammar Problem [message #1803747 is a reply to message #1803746] Fri, 08 March 2019 04:54 Go to previous messageGo to next message
Thanks for your reply.
I have more than one import region. Instead of Import we can see this like variables. I want to be able to specify in any place of my document "imports" (or variables) without a fix position as you are proposing. Besides that I want to specify "use" only one time in the document, and without a fix position.
[Updated on: Fri, 08 March 2019 05:08] by Moderator
Re: Grammar Problem [message #1803748 is a reply to message #1803747] Fri, 08 March 2019 04:57 Go to previous messageGo to next message
isnt that a
Model: (imports+=Import | a+=AThing| b+=BThing)*;
Re: Grammar Problem [message #1803749 is a reply to message #1803748] Fri, 08 March 2019 05:06 Go to previous messageGo to next message
No, because I can only specify "use" in the document once.
Re: Grammar Problem [message #1803750 is a reply to message #1803749] Fri, 08 March 2019 05:08 Go to previous messageGo to next message
well. a good advice when writing xtext grammars is:
you do NOT have to put everything into the grammar. it is always possible to write semantic validations which will make your live much easier
Re: Grammar Problem [message #1803751 is a reply to message #1803750] Fri, 08 March 2019 05:13 Go to previous messageGo to next message
Maybe it will be better to do that. Thanks :D
Re: Grammar Problem [message #1803752 is a reply to message #1803751] Fri, 08 March 2019 05:35 Go to previous message
Perhaps you should reread/understand my earlier answer. It can have 'use' exactly once as a body, surrounded by preamble/postamble.
Ed Willink
Previous Topic:Xtext Error Recovery
Next Topic:Template language
Current Time: Sun Nov 09 10:19:55 EST 2025
Powered by FUDForum. Page generated in 0.05050 seconds
