Home » Eclipse Projects » Eclipse Scout » HTML tags in mobile view(HTML doesn't seem to work in mobile view)
HTML tags in mobile view [message #1803328] Tue, 26 February 2019 18:51 Go to next message
I have a column in an AbstractPageWithTable<Table> which is getConfiguredHtmlEnabled = true, and it's data is an anchor tag. The link shows correctly in the desktop view, but in the mobile version, the HTML seems to be removed, and only the text shows up.
Thank you.
Re: HTML tags in mobile view [message #1803391 is a reply to message #1803328] Wed, 27 February 2019 14:21 Go to previous message
Hi there,
this has been fixed for the upcoming 9.0 release which will be released at the end of March. If you want to try it out now, you can use the current milestone build: 9.0.0.006_Simrel_2019_03_M3 (https://search.maven.org/search?q=g:org.eclipse.scout.rt%20AND%20v:9.0.0.006_Simrel_2019_03_M3).
Best,
Claudio
Previous Topic:Adding widget to project
Next Topic:Change session duration [MARS]
Current Time: Tue Jul 15 07:43:50 EDT 2025
Powered by FUDForum. Page generated in 0.49713 seconds
