Importing a project with git-lfs fails with git-lfs not found error [message #1802806] |
Sat, 16 February 2019 22:44 |
Y Kris Messages: 1 Registered: February 2019 |
Hi:
I am trying to import the https://github.com/knime/knime-workbench repository using git. The knime-workbench requires git-lfs. The import fails with the following error:
Git repository clone failed.
org.eclipse.jgit.api.errors.FilterFailedException: Execution of filter command 'git-lfs smudge -- 'org.knime.workbench.repository/lib/schemas.jar'' on file 'org.knime.workbench.repository/lib/schemas.jar' failed with return code '127', message on stderr: 'git-lfs smudge -- 'org.knime.workbench.repository/lib/schemas.jar': git-lfs: command not found
git-lfs is installed. When I open an eclipse terminal I can run git-lfs. So not sure why it says it cannot find git-lfs.
I saw a similar problem reported with e-git:
https://www.eclipse.org/forums/index.php/t/1077815/
But do not see a useful response there.
Thanks!
FUDForum. Page generated in 0.08760 seconds
