[SOLVED] Eclipse failed to launch workspace [message #1802540] |
Mon, 11 February 2019 17:00 |
Emilien Bourdy Messages: 5 Registered: December 2017 |
When I want to launch any workspace (even an empty one), Eclipse tells me that it can't launch it with an error in a log file. The error in my terminal is
org.eclipse.m2e.logback.configuration: Logback config file: /home/emilien/data/Scoopf/geo/.metadata/.plugins/org.eclipse.m2e.logback.configuration/logback.1.10.0.20181127-2120.xml
SLF4J: Class path contains multiple SLF4J bindings.
SLF4J: Found binding in [bundleresource://704.fwk825496893:1/org/slf4j/impl/StaticLoggerBinder.class]
SLF4J: Found binding in [bundleresource://704.fwk825496893:2/org/slf4j/impl/StaticLoggerBinder.class]
SLF4J: See http://www.slf4j.org/codes.html#multiple_bindings for an explanation.
SLF4J: Actual binding is of type [ch.qos.logback.classic.util.ContextSelectorStaticBinder]
org.eclipse.m2e.logback.configuration: Initializing logback
And the log file is attached.
I also tried to remove the plugins directories, but it's the same.
If anyone can help me it would be very nice!
Thanks in advance,
Emilien
[Updated on: Tue, 12 February 2019 13:50] Report message to a moderator
FUDForum. Page generated in 0.07704 seconds
