Re: Empty working sets created [message #1801743 is a reply to message #1801736] |
Fri, 25 January 2019 13:55 |
Ed Merks Messages: 33217 Registered: July 2009 |
You can quite easily look at other examples using Navigate -> Open Setup -> Parent Models -> Catalog Index Eclipse and then look at then look in the Eclipse Projects. Ctrl-F can be used to search, though it's a little flaky something...
The problem is your targlet has no requirements that it needs satisfied. The magical wildcard requirement is ideal for that purpose:<?xml version="1.0" encoding="UTF-8"?>
<p2:Requirement
xmi:version="2.0"
xmlns:p2="http://www.eclipse.org/oomph/p2/1.0"
name="*"/>
It expands to require everything in the source locator.
Ed Merks
FUDForum. Page generated in 0.03712 seconds
