Home » Newcomers » Newcomers » Set locale based on data(set locale based on country value in data)
Set locale based on data [message #1801629] Wed, 23 January 2019 16:34 Go to next message
I'm developing a compensation statement in BIRT that can contain several employees within the output. There are regulations in the EU, specifically France, that require the output in the country's language and fr_FR format for numbers. The statement already does localization, however it sets the locale for all output, not by employee. If I have a mix of employees, say US and France, I need to have the report dynamically change the locale for each employee (which are grouped-by Employee ID in the dataset). Basically, I need to set the locale for each Employee ID. I have a locale value defined in the dataset (row["localeDerived"]) and a function I modified to try to use this value but it is not working:
function getTranslation() {
if(arguments.length >0 ) {
var key = arguments[0];
var l10nParams = new Array();
for(var i=1; i < arguments.length; i++)
l10nParams.push(arguments[i]);
//return reportContext.getMessage(key, reportContext.getLocale(), l10nParams)
return reportContext.getMessage(key, row["localeDerived"], l10nParams)
return "";
Is there a way I can change the locale for each row in the dataset?
Re: Set locale based on data [message #1801642 is a reply to message #1801629] Thu, 24 January 2019 00:29 Go to previous messageGo to next message
It's likely best to ask on the BIRT forum: https://www.eclipse.org/forums/eclipse.birt
Re: Set locale based on data [message #1801644 is a reply to message #1801642] Thu, 24 January 2019 00:40 Go to previous message
Thanks Ed.
Moderator - you can remove this post. I re-posted the topic in the BIRT forum.
Previous Topic:Eclipse Titan
Next Topic:Removing plugins from Market Place
Current Time: Fri Sep 05 21:39:46 EDT 2025
Powered by FUDForum. Page generated in 0.08288 seconds
