Re: Plugin not working on latest Eclipse versions [message #1801126 is a reply to message #1801125] |
Mon, 14 January 2019 11:19 |
Ammad Ahmed Messages: 10 Registered: January 2019 |
On the main tab I have selected "Run an application" and in the dropdown "org.eclipse.ui.ide.workbench" . Plugins are selected using Launch option "plugins selected below only" from where i select my plugin from wrokspace after that i click the "add required plugins" button which seems to add "167 out of 464" other plugins. I can not find "org.apache.felix.scr" anywhere in the list of plugins.
[Updated on: Mon, 14 January 2019 12:25] Report message to a moderator
Re: Plugin not working on latest Eclipse versions [message #1801252 is a reply to message #1801228] |
Tue, 15 January 2019 20:38 |
Hi Ed, I tried again with the 4.8 repo and with the product to launch set as platform.ide. Now i can see the "org.apache.felix.scr " in the plugin list and it is already selected. Upon running it launches the eclipse photon instance and runs the plugin successfully. But when I create the jar file of the plugin and install it in the eclipse photon it crashes the eclipse with the same error log upon launching of eclipse.
[Updated on: Tue, 15 January 2019 20:42] Report message to a moderator
FUDForum. Page generated in 0.53736 seconds
