| Eclipse windows across multiple monitors [message #1800290] |
Sun, 23 December 2018 13:37  |
I'm recently starting to use Eclipse for C++ development. Before C++ I worked with mostly JS through Atom.
I am on MacOS 10.14
My largest issue with Eclipse right now is how it handles multiple windows on multiple monitors. I tried to put a window with a console and the breakpoints on the other monitor, this worked ok. However, any time a dialog popped up while focused on the other window, the debug pane would jump to there.
I then tried to use perspectives to save the layout of the views in the first debug pane. However, when I started the debug session, the original debug console and breakpoints pane popped up and the second monitor's window gained an editor for the debugged file.
When I looked around the forums here, I found very little about the monitor issues, and one post in the last year.
Besides the windows, I'm having a few other aggravating problems.
| Re: Eclipse windows across multiple monitors [message #1800482 is a reply to message #1800458] |
Sat, 29 December 2018 13:04  |
I did both, when I created a window by dragging it jumped like I said before. When I did create a new window, it started with an editor pane and a project view, as they were already on my first window I deleted them. When I actually started a debug session the origional layout was restored.
FUDForum. Page generated in 0.10613 seconds
