Home » Modeling » TMF (Xtext) » executing mwe2 programmatically within Eclipse plugin(executing mwe2 programmatically within Eclipse plugin)
executing mwe2 programmatically within Eclipse plugin [message #1799476] Fri, 07 December 2018 08:15 Go to next message
I want to invoke MWE2 workflow file from a eclipse plugin and expect that the runtime of the eclipse is being used during execution.
I have used below code with Mwe2Runner and Mwe2Launcher, but it does not seem to work and in both the cases I get exceptions.
Case 1: With Mwe2Runner
Injector injector = new Mwe2StandaloneSetup()
					.createInjectorAndDoEMFRegistration();
			Mwe2Runner runner = injector.getInstance(Mwe2Runner.class);
			URI uri = URI.createFileURI(getWorkFlowFilePath());
			runner.run(uri,
					new HashMap<>());
I get below exeption:
java.lang.IllegalStateException: [XtextLinkingDiagnostic: null:31 Couldn't resolve reference to JvmType 'com.pc.TestReader
In this case, it is clearly visible that eclipse runtime is not considered.
Case 2: With Mwe2Launcher
Mwe2Launcher.main(new String[] {URI.createFileURI(getWorkFlowFilePath()).toFileString()});
java.lang.IllegalStateException: Couldn't find module D:\01_Main\Test.mwe2
In this case I see that launcher is considering filePath as module name and failing :-(
Note: In both the case, I am fetching the path of workflow file with the below code and I see that it is completely valid
public static String getWorkFlowFilePath() {
		Bundle bundle = Platform.getBundle("com.project1");
		URL entry = bundle.getEntry("workflow/Test.mwe2");
		if (entry != null) {
			URL fileURL;
			try {
				fileURL = FileLocator.toFileURL(entry);
				if (fileURL != null) {
					 return fileURL.getFile();
			} catch (IOException e) {
				e.printStackTrace();
		return null;
It will be helpful if anyone of you can let me know how to solve this issue..
Thanks !!
Re: executing mwe2 programmatically within Eclipse plugin [message #1799477 is a reply to message #1799476] Fri, 07 December 2018 08:26 Go to previous messageGo to next message
did you have a look what the normal launch config does: are you sure the classpath is correct? are you sure the path is correct?
something like
{code}
public class Main {
"/data/2018-12/ws2222222/org.xtext.example.mydsl/src/org/xtext/example/mydsl/GenerateMyDsl.mwe2",
"-p",
"rootPath=/data/2018-12/ws2222222/"}
{code}
works fine for me
Re: executing mwe2 programmatically within Eclipse plugin [message #1799561 is a reply to message #1799477] Mon, 10 December 2018 05:28 Go to previous messageGo to next message
Hi Christian,
Thanks for your quick reply. I have used this code and still I have problems in execution of MWE2 from the eclipse plugin
I see that MWE2Launcher behaves differently when executed from a standalone java application (with main) and with eclipse application (launched as a eclipse application e.g: from a eclipse action or from a standalone RCP)
Major concern here is: in case of execution from eclipse application, dependencies are not resolved and MWE2Launcher throws an exception : illegalStateExection: [xtextlinkingdiagnostic]: couldn't resolve reference to JavaType '<defined in other plugin>'
To have a clear demonstration of this behaviour, I created two eclipse plugin and used the MWE2Launcher execution code from :
-simple java class containing main
- Eclipse headless RCP application
source code is available at : https://github.com/zam1kor/mwe2_execution/blob/c3676d4/src_code.zip?raw=true
Documentation : I have created step by step explanation of the plugins I have created + how I have used MWE2Launcher (in both the modes) : https://github.com/zam1kor/mwe2_execution/blob/c3676d4/Issue_description.docx?raw=true
info: both sources and docu are available in gitbu repo : https://github.com/zam1kor/mwe2_execution.git
Re: executing mwe2 programmatically within Eclipse plugin [message #1799567 is a reply to message #1799561] Mon, 10 December 2018 06:58 Go to previous messageGo to next message
you dont provide any classpath ?!?
Re: executing mwe2 programmatically within Eclipse plugin [message #1799568 is a reply to message #1799567] Mon, 10 December 2018 07:00 Go to previous messageGo to next message
=> you should debug?
Re: executing mwe2 programmatically within Eclipse plugin [message #1799569 is a reply to message #1799568] Mon, 10 December 2018 07:07 Go to previous messageGo to next message
it might be that org.eclipse.xtext.common.types.access.binary.BinaryClass.forName(String, ClassLoader) does not support this usecase
Re: executing mwe2 programmatically within Eclipse plugin [message #1799570 is a reply to message #1799569] Mon, 10 December 2018 07:10 Go to previous message
https://bugs.eclipse.org/bugs/show_bug.cgi?id=318721
Previous Topic:Unordered Groups - any Alternatives?
Next Topic:cross-reference with modified name
Current Time: Fri Nov 07 17:58:34 EST 2025
Powered by FUDForum. Page generated in 0.03862 seconds
