Home » Modeling » TMF (Xtext) » cross-reference with modified name
cross-reference with modified name [message #1799466] Fri, 07 December 2018 05:19 Go to next message
How do we make a language cross-reference to an object from another language/model with slightly different label?
Let me try to describe this further by giving a simplified scenario:
    1. I have language A with Definition as one of a class.
    2. My language B cross-reference the definition from model A.
    3. My language C also cross-reference the definition from model A.
    4. All above are working well. However, there is further requirements that B and C should display the definition slightly differently. e.g
      a. Say language A has definition 'Def1', 'Def2' and 'Def3'
      b. Now language B need to cross-reference as all in uppercase i.e 'DEF1', 'DEF2' and 'DEF3'
      c. Now language C need to cross-reference as all in lowercase i.e 'def1', 'def2' and 'def3'
    5. What this means is language B and C even though they refer to same definition object but each should render the label on their own way. Also I want the go-to-declaration feature to work.
    Maybe what I am looking for is something like from
    schemaName=[mib::Definition|MIB_ID]
    to
    schemaName=[mib::Definition.ucName|MIB_ID]
I am open to any suggestion. Thanks.
Re: cross-reference with modified name [message #1799467 is a reply to message #1799466] Fri, 07 December 2018 05:22 Go to previous messageGo to next message
have a look what xtext does for imports with AliasedEObjectDescription.
alterantively: index the elements under two names: adapt DefaultResourceDescriptionStrategy.
store for the names which variant they are in the user data.
in scoping use userdata to filter the correct name variant
Re: cross-reference with modified name [message #1799486 is a reply to message #1799467] Fri, 07 December 2018 11:03 Go to previous messageGo to next message
Here is what I have tried:
class LanguageBScopeProvider extends AbstractLanguageBScopeProvider {
	override getScope(EObject context, EReference reference) {
		if (context instanceof TableExpression) {
			if (reference == XcorePackage.Literals.TABLE_EXPRESSION__SCHEMA_NAME) {
				val scope = super.getScope(context, reference)
				val defs = scope.allElements.map([ d |
					new AliasedEObjectDescription(QualifiedName.create(d.name.firstSegment.toUpperCase), d)
				]).map([d|d as IEObjectDescription])
				return new SimpleScope(defs)
This allows the language B accepts language A's Definition object in lower case. However, the content assist still shows the definitions in original forms. (i.e Once selected, need to manually change case)
Anything I have done above is wrong? Or do I need to manually handle LanguageBProposalProvider as well? Thanks.
Corresponding Language B grammar:
TableExpression:
	(schemaName=[mib::Definition|MIB_ID] '.' tableName=[mib::Identifier] | '(' select=SelectStatement ')')
	('AS'? tableAlias=ID)?;
Re: cross-reference with modified name [message #1799488 is a reply to message #1799486] Fri, 07 December 2018 11:16 Go to previous messageGo to next message
Don't understand. Each DSL has its own scopeprovider
Re: cross-reference with modified name [message #1799492 is a reply to message #1799488] Fri, 07 December 2018 11:56 Go to previous messageGo to next message
Let me clarify.
The above code does allow me write def1 in language B to refer to Def1. However the autocomplete list still lists down as Def1, Def2 etc.
Is the later is expected? How do I fix it?
Re: cross-reference with modified name [message #1799498 is a reply to message #1799492] Fri, 07 December 2018 12:51 Go to previous messageGo to next message
The scoping in b is done in b
Re: cross-reference with modified name [message #1799584 is a reply to message #1799498] Mon, 10 December 2018 09:53 Go to previous messageGo to next message
Managed to reproduce the issue with simple LangA and LangB used in above example.
Here is xtext grammar for Lang A
grammar org.xtext.example.crr.langa.LangA with org.eclipse.xtext.common.Terminals
generate langA "http://www.xtext.org/example/crr/langa/LangA"
Model:
	definitions+=Definition*;
Definition:
	'set' name=ID 'as' value=INT;
Here is xtext grammar for Lang B
grammar org.xtext.example.crr.langb.LangB with org.eclipse.xtext.common.Terminals
generate langB "http://www.xtext.org/example/crr/langb/LangB"
import "http://www.xtext.org/example/crr/langa/LangA" as langA
Model:
	uses1+=Use1*
	uses2+=Use2*;
Use1:
	'use1' name=[langA::Definition]
Use2:
	'use2' name=UseRef ;
UseRef:
And LangA definition has been eobject aliased in LangB's scope as follow:
class LangBScopeProvider extends AbstractLangBScopeProvider {
		if (context instanceof Use1) {
			if (reference == LangBPackage.Literals.USE1__NAME) {
				println("USE1__NAME")
		if (context instanceof UseRef) {
			if (reference == LangBPackage.Literals.USE_REF__NAME) {
				println("USE_REF__NAME")
And the above mentioned issue can be reproduced as shown in the image below
index.php/fa/34485/0/
The different between LangB-"use1"-way and LangB-"use2"-way is the cross-reference is specified with a keyword (works) and does not work when cross-reference is in its own object/rule i.e UseRef.
I do not understand the behaviour. helps if you can clarify it.
Attached is the source code to reproduce the issue.
[Updated on: Mon, 10 December 2018 09:54] by Moderator
Re: cross-reference with modified name [message #1799599 is a reply to message #1799584] Mon, 10 December 2018 16:18 Go to previous messageGo to next message
this is a different problem.
Xtext creates objects lazy (usually)
that means "after" the first assignment
in your grammar you have
Use2:
UseRef:
=> the context may be a Use2 or even a Model (depending on situation), that is expected behaviour.
=> you have to consider that in your scoping impl.
you can otherwise mitigate it by changing the grammar (depends on the situation if this is possible)
Use2:
name=UseRef ;
UseRef:
{UseRef}'use2' name=[langA::Definition]
the label in the completion is done there:org.eclipse.xtext.resource.impl.AliasedEObjectDescription.getQualifiedName()
called by org.eclipse.xtext.ui.editor.contentassist.AbstractContentProposalProvider.getStyledDisplayString(IEObjectDescription)
you might custoize that in your proposal provider
Re: cross-reference with modified name [message #1799605 is a reply to message #1799599] Mon, 10 December 2018 19:47 Go to previous message
Thanks Christian, that explained it.
In my case, since context does not have to be fixed - I able just to skip the check. i.e this works.
//		if (context instanceof UseRef) {
//			if (reference == LangBPackage.Literals.USE_REF__NAME) {
//				val scope = super.getScope(context, reference)
//				println("USE_REF__NAME")
//				val defs = scope.allElements.map([ d |
//					new AliasedEObjectDescription(QualifiedName.create(d.name.firstSegment.toUpperCase), d)
//				]).map([d|d as IEObjectDescription])
//				return new SimpleScope(defs)
			println("none UseRef USE_REF__NAME")
Previous Topic:executing mwe2 programmatically within Eclipse plugin
Next Topic:Xtext DSL plugin only provides keyword suggestions for the first line of the file
Current Time: Fri Nov 07 19:19:04 EST 2025
Powered by FUDForum. Page generated in 0.04227 seconds
