Home » Modeling » TMF (Xtext) » Most convenient way to include third party dependencies
Most convenient way to include third party dependencies [message #1798762] Fri, 23 November 2018 11:54 Go to next message
The goal is to include simple commonly used artifacts like hibernate or slf4j within the xtext project.
At the moment all topics I found seem to fall back to this "solution":
https://wiki.eclipse.org/Tycho/How_Tos/Dependency_on_pom-first_artifacts
It seems weird that you need to create a second pom-first build reactor just to include commonly needed dependencies into the tycho build.
Is this still the solution to use or is there a newer approach to include such dependencies?
Maybe I just didn't find the correct update site url for the target platform configuration?
(PS: At the moment our projects use 2.13)
[Updated on: Fri, 23 November 2018 11:54] by Moderator
Re: Most convenient way to include third party dependencies [message #1798763 is a reply to message #1798762] Fri, 23 November 2018 11:56 Go to previous messageGo to next message
if you use tycho you can add stuff to your target platform as long as it is available via p2 repo.
luckily there is eclipse orbit. and maybe it contains what you need
https://download.eclipse.org/tools/orbit/downloads/drops/R20180905201904/
Re: Most convenient way to include third party dependencies [message #1798766 is a reply to message #1798762] Fri, 23 November 2018 12:44 Go to previous messageGo to next message
Also when using Tycho it is possible to add Maven dependencies to the target platform computation when configuring pomDependencies = consider. The artifacts must contain a valid OSGi MANIFEST.MF, which is not true for many artifacts.
https://wiki.eclipse.org/Tycho/Target_Platform#.22POM_dependencies_consider.22
Re: Most convenient way to include third party dependencies [message #1798824 is a reply to message #1798763] Mon, 26 November 2018 05:39 Go to previous messageGo to next message
Christian Dietrich wrote on Fri, 23 November 2018 16:56
Thank you for the hint. By a quick look the only thing missing that I spotted was hibernate. (but since that will occure mostly in annotations maybe it could work without it)
Karsten Thoms wrote on Fri, 23 November 2018 17:44
This is one of the parts where I struggled with my first attempts. Regardig to:
"Tycho target-platform-configuration/pomDependencies=consider is restricted to packaging=jar"
This conflicts with the xtext packaging of eclipse-plugin etc.
If this restriction to "packaging=jar"is still correct, than I don't really have a choice within the xtext project structure and need to create a second reactor for the dependencies, right?
Beside the fact that if there is a dependency for which there is no p2 or correct osgi meta data, again, I am in need of the second reactor to handle the dependencies. Considering I want to build a structure that lasts a bit longer and is easy to understand and maintain for my colleague (that are most likely not that familiar with tycho and the dependency "evil pits") there should be a structure that handles "new" dependencies.
With the xtest structure at the moment not having a permanent solution for the dependency "war" is just delaying the problem and "hoping for the best".
This also sounds like a good idea for a new optional part/feature of the xtext project structure, doesn't it? ;)
I believe that I'm one of many that struggled with that concept and the conflicts from the dependency war. It seems to be a common usecase and a common struggle. :(
Re: Most convenient way to include third party dependencies [message #1799003 is a reply to message #1798824] Wed, 28 November 2018 09:50 Go to previous message
Can anybody help with a hibernate osgi bundles or repository? (goal is: hibernate-core not the hibernate-osgi module ;) )
The search was frustrating and annoying so far.
Spring hosted OSGI bundles for hibernate within their repository... As far as the short stack-overflow topics mention: they are not continued anymore.
Hibernate seems to be a bigger commonly used framework. So maybe you already have a solution? (other than the second reactor)
PS: All other needed dependencies were included within the link from Christian! Thanks again!
[Updated on: Wed, 28 November 2018 09:51] by Moderator
Previous Topic:Switch case problem with JvmTypeReference
Next Topic:Xtext version working with Java 11
Current Time: Fri Nov 07 19:18:58 EST 2025
Powered by FUDForum. Page generated in 0.11322 seconds
