Home » Archived » Eclipse SmartHome » Compilation failure
Compilation failure [message #1798600] Tue, 20 November 2018 16:06 Go to next message
I am unable to compile the latest eclipse/smarthome. It worked last week. :)
I have tried git clean -x -d -f, I've re-run "Perform Setup Tasks..." in Eclipse, I've even nuked my local ~/.m2/repository, but the build always fails.
[INFO] ------------------------------------------------------------------------
[INFO] BUILD FAILURE
[INFO] Total time: 02:39 min
[INFO] Finished at: 2018-11-20T18:14:55Z
[ERROR] Failed to execute goal org.eclipse.tycho:tycho-compiler-plugin:1.2.0:compile (default-compile) on project org.eclipse.smarthome.ui: Compilation failure: Compilation failure:
[ERROR] /Users/evansj/src/home_automation/smarthome-master/git/smarthome/bundles/ui/org.eclipse.smarthome.ui/src/main/java/org/eclipse/smarthome/ui/internal/items/ItemUIRegistryImpl.java:[280]
[ERROR] 	List<Mapping> mappings = playerItemSwitch.getMappings();
[ERROR] 	                                          ^^^^^^^^^^^
[ERROR] The method getMappings() from the type Switch refers to the missing type EList
[ERROR] /Users/evansj/src/home_automation/smarthome-master/git/smarthome/bundles/ui/org.eclipse.smarthome.ui/src/main/java/org/eclipse/smarthome/ui/internal/items/ItemUIRegistryImpl.java:[350]
[ERROR] 	logger.error("Cannot retrieve item for widget {}", w.eClass().getInstanceTypeName());
[ERROR] 	                                                     ^^^^^^
[ERROR] The method eClass() is undefined for the type Widget
[ERROR] /Users/evansj/src/home_automation/smarthome-master/git/smarthome/bundles/ui/org.eclipse.smarthome.ui/src/main/java/org/eclipse/smarthome/ui/internal/items/ItemUIRegistryImpl.java:[544]
[ERROR] 	String widgetTypeName = w.eClass().getInstanceTypeName()
[ERROR] 	                          ^^^^^^
[ERROR] /Users/evansj/src/home_automation/smarthome-master/git/smarthome/bundles/ui/org.eclipse.smarthome.ui/src/main/java/org/eclipse/smarthome/ui/internal/items/ItemUIRegistryImpl.java:[545]
[ERROR] 	.substring(w.eClass().getInstanceTypeName().lastIndexOf(".") + 1);
[ERROR] 	             ^^^^^^
[ERROR] /Users/evansj/src/home_automation/smarthome-master/git/smarthome/bundles/ui/org.eclipse.smarthome.ui/src/main/java/org/eclipse/smarthome/ui/internal/items/ItemUIRegistryImpl.java:[575]
[ERROR] 	new Object[] { itemName, w.eClass().getInstanceTypeName() });
[ERROR] 	                           ^^^^^^
[ERROR] /Users/evansj/src/home_automation/smarthome-master/git/smarthome/bundles/ui/org.eclipse.smarthome.ui/src/main/java/org/eclipse/smarthome/ui/internal/items/ItemUIRegistryImpl.java:[609]
[ERROR] 	if (sw.getMappings().size() == 0) {
[ERROR] 	       ^^^^^^^^^^^
[ERROR] /Users/evansj/src/home_automation/smarthome-master/git/smarthome/bundles/ui/org.eclipse.smarthome.ui/src/main/java/org/eclipse/smarthome/ui/internal/items/ItemUIRegistryImpl.java:[636]
[ERROR] 	if (widgetID < sitemap.getChildren().size()) {
[ERROR] 	                       ^^^^^^^^^^^
[ERROR] The method getChildren() from the type Sitemap refers to the missing type EList
[ERROR] /Users/evansj/src/home_automation/smarthome-master/git/smarthome/bundles/ui/org.eclipse.smarthome.ui/src/main/java/org/eclipse/smarthome/ui/internal/items/ItemUIRegistryImpl.java:[637]
[ERROR] 	w = sitemap.getChildren().get(widgetID);
[ERROR] 	            ^^^^^^^^^^^
[ERROR] /Users/evansj/src/home_automation/smarthome-master/git/smarthome/bundles/ui/org.eclipse.smarthome.ui/src/main/java/org/eclipse/smarthome/ui/internal/items/ItemUIRegistryImpl.java:[640]
[ERROR] 	if (childWidgetID < ((LinkableWidget) w).getChildren().size()) {
[ERROR] 	                                         ^^^^^^^^^^^
[ERROR] The method getChildren() from the type LinkableWidget refers to the missing type EList
[ERROR] /Users/evansj/src/home_automation/smarthome-master/git/smarthome/bundles/ui/org.eclipse.smarthome.ui/src/main/java/org/eclipse/smarthome/ui/internal/items/ItemUIRegistryImpl.java:[641]
[ERROR] 	w = ((LinkableWidget) w).getChildren().get(childWidgetID);
[ERROR] 	                         ^^^^^^^^^^^
[ERROR] /Users/evansj/src/home_automation/smarthome-master/git/smarthome/bundles/ui/org.eclipse.smarthome.ui/src/main/java/org/eclipse/smarthome/ui/internal/items/ItemUIRegistryImpl.java:[657]
[ERROR] 	EList<Widget> widgets = sitemap.getChildren();
[ERROR] 	                                ^^^^^^^^^^^
[ERROR] /Users/evansj/src/home_automation/smarthome-master/git/smarthome/bundles/ui/org.eclipse.smarthome.ui/src/main/java/org/eclipse/smarthome/ui/internal/items/ItemUIRegistryImpl.java:[672]
[ERROR] 	if (w instanceof Group && w.getChildren().isEmpty()) {
[ERROR] 	                            ^^^^^^^^^^^
[ERROR] /Users/evansj/src/home_automation/smarthome-master/git/smarthome/bundles/ui/org.eclipse.smarthome.ui/src/main/java/org/eclipse/smarthome/ui/internal/items/ItemUIRegistryImpl.java:[675]
[ERROR] 	widgets = w.getChildren();
[ERROR] 	            ^^^^^^^^^^^
[ERROR] /Users/evansj/src/home_automation/smarthome-master/git/smarthome/bundles/ui/org.eclipse.smarthome.ui/src/main/java/org/eclipse/smarthome/ui/internal/items/ItemUIRegistryImpl.java:[691]
[ERROR] 	return (w2 == null) ? w.eContainer() : w2.eContainer();
[ERROR] 	                        ^^^^^^^^^^
[ERROR] The method eContainer() is undefined for the type Widget
[ERROR] 	                                          ^^^^^^^^^^
[ERROR] /Users/evansj/src/home_automation/smarthome-master/git/smarthome/bundles/ui/org.eclipse.smarthome.ui/src/main/java/org/eclipse/smarthome/ui/internal/items/ItemUIRegistryImpl.java:[718]
[ERROR] 	target.getVisibility().addAll(EcoreUtil.copyAll(source.getVisibility()));
[ERROR] 	       ^^^^^^^^^^^^^
[ERROR] The method getVisibility() from the type Widget refers to the missing type EList
[ERROR] /Users/evansj/src/home_automation/smarthome-master/git/smarthome/bundles/ui/org.eclipse.smarthome.ui/src/main/java/org/eclipse/smarthome/ui/internal/items/ItemUIRegistryImpl.java:[719]
[ERROR] 	target.getLabelColor().addAll(EcoreUtil.copyAll(source.getLabelColor()));
[ERROR] The method getLabelColor() from the type Widget refers to the missing type EList
[ERROR] /Users/evansj/src/home_automation/smarthome-master/git/smarthome/bundles/ui/org.eclipse.smarthome.ui/src/main/java/org/eclipse/smarthome/ui/internal/items/ItemUIRegistryImpl.java:[720]
[ERROR] 	target.getValueColor().addAll(EcoreUtil.copyAll(source.getValueColor()));
[ERROR] The method getValueColor() from the type Widget refers to the missing type EList
[ERROR] /Users/evansj/src/home_automation/smarthome-master/git/smarthome/bundles/ui/org.eclipse.smarthome.ui/src/main/java/org/eclipse/smarthome/ui/internal/items/ItemUIRegistryImpl.java:[865]
[ERROR] 	while (w.eContainer() instanceof Widget) {
[ERROR] 	         ^^^^^^^^^^
[ERROR] /Users/evansj/src/home_automation/smarthome-master/git/smarthome/bundles/ui/org.eclipse.smarthome.ui/src/main/java/org/eclipse/smarthome/ui/internal/items/ItemUIRegistryImpl.java:[866]
[ERROR] 	Widget parent = (Widget) w.eContainer();
[ERROR] 	                           ^^^^^^^^^^
[ERROR] /Users/evansj/src/home_automation/smarthome-master/git/smarthome/bundles/ui/org.eclipse.smarthome.ui/src/main/java/org/eclipse/smarthome/ui/internal/items/ItemUIRegistryImpl.java:[867]
[ERROR] 	String index = String.valueOf(((LinkableWidget) parent).getChildren().indexOf(w));
[ERROR] 	                                                        ^^^^^^^^^^^
[ERROR] /Users/evansj/src/home_automation/smarthome-master/git/smarthome/bundles/ui/org.eclipse.smarthome.ui/src/main/java/org/eclipse/smarthome/ui/internal/items/ItemUIRegistryImpl.java:[874]
[ERROR] 	if (w.eContainer() instanceof Sitemap) {
[ERROR] 	      ^^^^^^^^^^
[ERROR] /Users/evansj/src/home_automation/smarthome-master/git/smarthome/bundles/ui/org.eclipse.smarthome.ui/src/main/java/org/eclipse/smarthome/ui/internal/items/ItemUIRegistryImpl.java:[875]
[ERROR] 	Sitemap sitemap = (Sitemap) w.eContainer();
[ERROR] 	                              ^^^^^^^^^^
[ERROR] /Users/evansj/src/home_automation/smarthome-master/git/smarthome/bundles/ui/org.eclipse.smarthome.ui/src/main/java/org/eclipse/smarthome/ui/internal/items/ItemUIRegistryImpl.java:[876]
[ERROR] 	String index = String.valueOf(sitemap.getChildren().indexOf(w));
[ERROR] 	                                      ^^^^^^^^^^^
[ERROR] /Users/evansj/src/home_automation/smarthome-master/git/smarthome/bundles/ui/org.eclipse.smarthome.ui/src/main/java/org/eclipse/smarthome/ui/internal/items/ItemUIRegistryImpl.java:[885]
[ERROR] 	if (w.eContainer() == null) {
[ERROR] 	      ^^^^^^^^^^
[ERROR] /Users/evansj/src/home_automation/smarthome-master/git/smarthome/bundles/ui/org.eclipse.smarthome.ui/src/main/java/org/eclipse/smarthome/ui/internal/items/ItemUIRegistryImpl.java:[1111]
[ERROR] 	return processColorDefinition(getState(w), w.getLabelColor());
[ERROR] /Users/evansj/src/home_automation/smarthome-master/git/smarthome/bundles/ui/org.eclipse.smarthome.ui/src/main/java/org/eclipse/smarthome/ui/internal/items/ItemUIRegistryImpl.java:[1116]
[ERROR] 	return processColorDefinition(getState(w), w.getValueColor());
[ERROR] /Users/evansj/src/home_automation/smarthome-master/git/smarthome/bundles/ui/org.eclipse.smarthome.ui/src/main/java/org/eclipse/smarthome/ui/internal/items/ItemUIRegistryImpl.java:[1122]
[ERROR] 	List<VisibilityRule> ruleList = w.getVisibility();
[ERROR] /Users/evansj/src/home_automation/smarthome-master/git/smarthome/bundles/ui/org.eclipse.smarthome.ui/src/main/java/org/eclipse/smarthome/ui/internal/items/ItemUIRegistryImpl.java:[1132]
[ERROR] 	for (VisibilityRule rule : w.getVisibility()) {
[ERROR] /Users/evansj/src/home_automation/smarthome-master/git/smarthome/bundles/ui/org.eclipse.smarthome.ui/src/main/java/org/eclipse/smarthome/ui/internal/items/ItemUIRegistryImpl.java:[1148]
[ERROR] 	w.eClass().getInstanceTypeName());
[ERROR] 	  ^^^^^^
[ERROR] 33 problems (33 errors)
[ERROR] -> [Help 1]
[ERROR]
[ERROR] To see the full stack trace of the errors, re-run Maven with the -e switch.
[ERROR] Re-run Maven using the -X switch to enable full debug logging.
[ERROR]
[ERROR] For more information about the errors and possible solutions, please read the following articles:
[ERROR] [Help 1] http://cwiki.apache.org/confluence/display/MAVEN/MojoFailureException
[ERROR]
[ERROR] After correcting the problems, you can resume the build with the command
[ERROR]   mvn <goals> -rf :org.eclipse.smarthome.ui
Re: Compilation failure [message #1798755 is a reply to message #1798600] Fri, 23 November 2018 10:44 Go to previous message
I'd imagine that this is due to the Java version being used. Which one is it? Can you try with Java 8, if it is anything more recent?
Previous Topic:ESH + Authorisation + OPTIONS method
Next Topic:SSE(Server Sent Events) not working through domain name URL
Current Time: Sun Oct 19 19:33:16 EDT 2025
Powered by FUDForum. Page generated in 0.05764 seconds
