Home » Language IDEs » Andmore » Can't install Eclipse
Can't install Eclipse [message #1798372] Fri, 16 November 2018 09:49
Svetoslav Hadziivanov is currently offline Svetoslav HadziivanovFriend
I can't install Eclipse due to the following reason:
[2018-11-16 09:01:31] Repository http://download.eclipse.org/oomph/updates/milestone/latest
[2018-11-16 09:01:32] ERROR: org.eclipse.equinox.p2.metadata.repository code=1000 No repository found at http://download.eclipse.org/oomph/updates/milestone/latest.
  at org.eclipse.equinox.internal.p2.repository.helpers.AbstractRepositoryManager.fail(AbstractRepositoryManager.java:398)
  at org.eclipse.oomph.util.ReflectUtil.invokeMethod(ReflectUtil.java:117)
  at org.eclipse.oomph.p2.internal.core.CachingRepositoryManager.fail(CachingRepositoryManager.java:353)
  at org.eclipse.oomph.p2.internal.core.CachingRepositoryManager.loadRepository(CachingRepositoryManager.java:244)
  at org.eclipse.oomph.p2.internal.core.CachingRepositoryManager$Metadata.loadRepository(CachingRepositoryManager.java:476)
  at org.eclipse.equinox.internal.p2.metadata.repository.MetadataRepositoryManager.loadRepository(MetadataRepositoryManager.java:110)
  at org.eclipse.equinox.internal.p2.metadata.repository.MetadataRepositoryManager.loadRepository(MetadataRepositoryManager.java:105)
  at org.eclipse.oomph.p2.internal.core.ProfileTransactionImpl$RepositoryLoader$Worker.perform(ProfileTransactionImpl.java:1613)
  at org.eclipse.oomph.util.WorkerPool$Worker.run(WorkerPool.java:428)
  at org.eclipse.core.internal.jobs.Worker.run(Worker.java:63)
If I try to update Eclipse (Portable version), it says
No repository found at http://download.eclipse.org/oomph/uss/updates/latest.
I couldn't create Maven project as well due to the same issue.
Any fix?
Previous Topic:Eclipse photon window size larger than pixelbook screen
Next Topic:org.xml.sax.SAXParseException: Content is not allowed in prolog
Current Time: Sat Apr 27 01:15:33 GMT 2024
Powered by FUDForum. Page generated in 0.04217 seconds
