Re: eclipse cannot import project from archive file [message #1798130 is a reply to message #1797945] |
Tue, 13 November 2018 06:41 |
Patrick Moran Messages: 141 Registered: March 2018 |
You didn't say which version of Eclipse you are using. I recently tried to switch to Photon and had lots of similar-sounding problems.
If I had a project I wanted to import and it was in the form of a zip file, I would get it unzipped. Then I suppose I might have had a folder called listenersDemo. Whatever it was, I would probably create a new workspace and move the project into that folder. (I guess I would open the originally zipped folder first to see whether it looked o.k.) Then in Eclipse I would change workspace and after Eclipse started itself it would show no projects in the new workspace. So the next thing to do would be to import the file into the open workspace in Eclipse. Once that was done, it should be possible to work on it in the ordinary way..
[Updated on: Tue, 13 November 2018 15:40] Report message to a moderator
FUDForum. Page generated in 0.08276 seconds
