Re: For the Designers among you: We need a new logo and icon [message #1818414 is a reply to message #1797184] |
Sat, 14 December 2019 19:48  |
Normally, if you are unsure as to where the problem occurs in the source code, you would ask the developers about it on the bug so that they can provide you with some pointers. If the bug is with the user interface, like it is with bug 221652, then you can try figuring it out yourself by using Plug-in Spy to find the source code based on the results of the introspection operation.
To use Plug-in Spy, you should first bring up the user interface element that the bug occurs in. Now hover your mouse over it and then hit Alt+Shift+F1 (this may be Option+Shift+F1 on a Mac keyboard). Plug-in Spy will analyze the element under your mouse cursor and provide you with a list of information.
Once you have the source code in your Eclipse workspace, you should startup a second Eclipse instance from your workspace that uses the plug-in you just checked out. You can then verify whether the bug is still reproducible with the latest code in the repository. In your 'Eclipse Application' launch configuration, make sure you have your checked out project selected and the one in your target platform unselected to ensure that PDE picks the right one.
You can try this out, it worked for me.
FUDForum. Page generated in 0.04023 seconds
