Generate dp file [message #1797014] |
Wed, 24 October 2018 07:18 |
shubh wade Messages: 28 Registered: July 2018 |
Hello
I want create dp file at run-time as we follow manually steps to create .dp through the .dpp file.Is there any api or something to build .dpp file into .dp file at run-time.I don't want to do this steps manually.
[Updated on: Wed, 24 October 2018 07:19] Report message to a moderator
Re: Generate dp file [message #1797029 is a reply to message #1797026] |
Wed, 24 October 2018 09:48 |
Yes i have added the maven dp pulgin to pom.xml
<plugin>
<groupId>de.dentrassi.maven</groupId>
<artifactId>osgi-dp</artifactId>
<version>0.3.0</version>
</plugin>
But when i run project with maven build i received this errors .
[INFO] Scanning for projects...
[INFO]
[INFO] ------------------------------------------------------------------------
[INFO] Building org.eclipse.kura.demo.heater 0.0.1-SNAPSHOT
[INFO] BUILD FAILURE
[INFO] Total time: 0.102 s
[INFO] Finished at: 2018-10-24T15:13:15+05:30
[INFO] Final Memory: 5M/119M
[ERROR] Unknown lifecycle phase "build". You must specify a valid lifecycle phase or a goal in the format <plugin-prefix>:<goal> or <plugin-group-id>:<plugin-artifact-id>[:<plugin-version>]:<goal>. Available lifecycle phases are: validate, initialize, generate-sources, process-sources, generate-resources, process-resources, compile, process-classes, generate-test-sources, process-test-sources, generate-test-resources, process-test-resources, test-compile, process-test-classes, test, prepare-package, package, pre-integration-test, integration-test, post-integration-test, verify, install, deploy, pre-clean, clean, post-clean, pre-site, site, post-site, site-deploy. -> [Help 1]
[ERROR]
[ERROR] To see the full stack trace of the errors, re-run Maven with the -e switch.
[ERROR] Re-run Maven using the -X switch to enable full debug logging.
[ERROR]
[ERROR] For more information about the errors and possible solutions, please read the following articles:
[Updated on: Wed, 24 October 2018 09:51] Report message to a moderator
FUDForum. Page generated in 0.04102 seconds
