Home » Modeling » TMF (Xtext) » XText Web. How finds ACE the Language Server?
Re: XText Web. How finds ACE the Language Server? [message #1796938 is a reply to message #1796935] |
Mon, 22 October 2018 15:33 |
Hello Markus, Xtext Web and LSP have currently zero relation.
So the answer is not at all
The servlet is called from the client JavaScript code.
If you create a web project with gradle or maven
And launch jetty via launcher in the web project or maven or gradle
Then you should be able to observe communication with your browser web tools.
Please Note. Might be necessary to have least the H in the Hello Would example to get content assist working
Twitter : @chrdietrich
Re: XText Web. How finds ACE the Language Server? [message #1799471 is a reply to message #1799469] |
Fri, 07 December 2018 11:45 |
Markus Häge Messages: 56 Registered: August 2018 |
Member |
I found two tutorials to add this websocket to monaco and xtext language server.
To connect it i use: const url = 'ws://localhost:4389', in the editor and commandline says it's connected.
The editor code has following:
// register Monaco languages
monaco.languages.register({
extensions: ['mydsl'],
aliases: ['MYDSL'],
mimetypes: ['application/Java'],
and
const editor = monaco.editor.create(document.getElementById("container")!, {
model: monaco.editor.createModel(value, 'mydsl',monaco.Uri.parse('inmemory:/MyDslParser')),
glyphMargin: true,
lightbulb: {
enabled: true
No idea how to teach Monaco mydsl from the server. I tried some things in ths Uri.parse(), but failed
Re: XText Web. How finds ACE the Language Server? [message #1799703 is a reply to message #1799626] |
Wed, 12 December 2018 17:12 |
Member |
Hi ,
i don't find code to uncomment in LS-Repo.
Here is the client, or what I think the client is
Markus
* Copyright (c) 2018 TypeFox GmbH (http://www.typefox.io). All rights reserved.
* Licensed under the MIT License. See License.txt in the project root for license information.
import { listen, MessageConnection } from 'vscode-ws-jsonrpc';
import {
MonacoLanguageClient, CloseAction, ErrorAction,
MonacoServices, createConnection
} from 'monaco-languageclient';
const ReconnectingWebSocket = require('reconnecting-websocket');
//monaco.languages.register({
// id: 'json',
// extensions: ['.json', '.bowerrc', '.jshintrc', '.jscsrc', '.eslintrc', '.babelrc'],
// aliases: ['JSON', 'json'],
// mimetypes: ['application/json'],
// create Monaco editor
const value = `{
"$schema": "http://json.schemastore.org/coffeelint",
"line_endings": "unix"
model: monaco.editor.createModel(value, 'mydsl', monaco.Uri.parse('inmemory://model.mydsl')),
glyphMargin: true,
lightbulb: {
enabled: true
// install Monaco language client services
MonacoServices.install(editor);
// create the web socket
const webSocket = createWebSocket(url);
// listen when the web socket is opened
listen({
webSocket,
onConnection: connection => {
// create and start the language client
const languageClient = createLanguageClient(connection);
const disposable = languageClient.start();
connection.onClose(() => disposable.dispose());
function createLanguageClient(connection: MessageConnection): MonacoLanguageClient {
return new MonacoLanguageClient({
name: "Sample Language Client",
clientOptions: {
// use a language id as a document selector
documentSelector: ['mydsl'],
// disable the default error handler
errorHandler: {
error: () => ErrorAction.Continue,
closed: () => CloseAction.DoNotRestart
// create a language client connection from the JSON RPC connection on demand
connectionProvider: {
get: (errorHandler, closeHandler) => {
return Promise.resolve(createConnection(connection, errorHandler, closeHandler))
function createWebSocket(url: string): WebSocket {
const socketOptions = {
maxReconnectionDelay: 10000,
minReconnectionDelay: 1000,
reconnectionDelayGrowFactor: 1.3,
connectionTimeout: 10000,
maxRetries: Infinity,
debug: false
return new ReconnectingWebSocket(url, undefined, socketOptions);
Re: XText Web. How finds ACE the Language Server? [message #1799768 is a reply to message #1799750] |
Thu, 13 December 2018 11:18 |
Member |
With RunWebSocketServer3 i get now in the (Run-Mode) (In Debug Mode i get Websocketnotconnected)
gogogo
start
open
message: {"jsonrpc":"2.0","id":0,"method":"initialize","params":{"rootPath":null,"rootUri":null,"capabilities":{"workspace":{"applyEdit":true,"workspaceEdit":{"documentChanges":true},"didChangeConfiguration":{"dynamicRegistration":true},"didChangeWatchedFiles":{"dynamicRegistration":true},"symbol":{"dynamicRegistration":true,"symbolKind":{"valueSet":[1,2,3,4,5,6,7,8,9,10,11,12,13,14,15,16,17,18,19,20,21,22,23,24,25,26]}},"executeCommand":{"dynamicRegistration":true},"workspaceFolders":true},"textDocument":{"publishDiagnostics":{"relatedInformation":true},"synchronization":{"dynamicRegistration":true,"willSave":true,"willSaveWaitUntil":true,"didSave":true},"completion":{"dynamicRegistration":true,"contextSupport":true,"completionItem":{"snippetSupport":true,"commitCharactersSupport":true,"documentationFormat":["markdown","plaintext"],"deprecatedSupport":true,"preselectSupport":true},"completionItemKind":{"valueSet":[1,2,3,4,5,6,7,8,9,10,11,12,13,14,15,16,17,18,19,20,21,22,23,24,25]}},"hover":{"dynamicRegistration":true,"contentFormat":["markdown","plaintext"]},"signatureHelp":{"dynamicRegistration":true,"signatureInformation":{"documentationFormat":["markdown","plaintext"]}},"definition":{"dynamicRegistration":true},"references":{"dynamicRegistration":true},"documentHighlight":{"dynamicRegistration":true},"documentSymbol":{"dynamicRegistration":true,"symbolKind":{"valueSet":[1,2,3,4,5,6,7,8,9,10,11,12,13,14,15,16,17,18,19,20,21,22,23,24,25,26]},"hierarchicalDocumentSymbolSupport":true},"codeAction":{"dynamicRegistration":true,"codeActionLiteralSupport":{"codeActionKind":{"valueSet":["","quickfix","refactor","refactor.extract","refactor.inline","refactor.rewrite","source","source.organizeImports"]}}},"codeLens":{"dynamicRegistration":true},"formatting":{"dynamicRegistration":true},"rangeFormatting":{"dynamicRegistration":true},"onTypeFormatting":{"dynamicRegistration":true},"rename":{"dynamicRegistration":true},"documentLink":{"dynamicRegistration":true},"typeDefinition":{"dynamicRegistration":true},"implementation":{"dynamicRegistration":true},"colorProvider":{"dynamicRegistration":true},"foldingRange":{"dynamicRegistration":true,"rangeLimit":5000,"lineFoldingOnly":true}}},"trace":"off","workspaceFolders":null}}
{"jsonrpc":"2.0","id":0,"result":{"capabilities":{"textDocumentSync":2,"hoverProvider":true,"completionProvider":{"resolveProvider":false,"triggerCharacters":["."]},"signatureHelpProvider":{"triggerCharacters":["(",","]},"definitionProvider":true,"referencesProvider":true,"documentHighlightProvider":true,"documentSymbolProvider":true,"workspaceSymbolProvider":true,"codeActionProvider":true,"documentFormattingProvider":true,"documentRangeFormattingProvider":true,"renameProvider":true,"executeCommandProvider":{"commands":["mydsl.a","mydsl.b","mydsl.c"]},"semanticHighlighting":{"scopes":[]}}}}
message: {"jsonrpc":"2.0","method":"initialized","params":{}}
open
Dez 13, 2018 12:17:20 PM org.eclipse.lsp4j.jsonrpc.RemoteEndpoint fallbackResponseError
SCHWERWIEGEND: Internal error: java.lang.reflect.InvocationTargetException
java.lang.RuntimeException: java.lang.reflect.InvocationTargetException
at org.eclipse.lsp4j.jsonrpc.services.GenericEndpoint.lambda$null$0(GenericEndpoint.java:67)
at org.eclipse.lsp4j.jsonrpc.services.GenericEndpoint.request(GenericEndpoint.java:120)
at org.eclipse.lsp4j.jsonrpc.RemoteEndpoint.handleRequest(RemoteEndpoint.java:261)
at org.eclipse.lsp4j.jsonrpc.RemoteEndpoint.consume(RemoteEndpoint.java:190)
at org.eclipse.lsp4j.jsonrpc.json.StreamMessageProducer.handleMessage(StreamMessageProducer.java:192)
at org.eclipse.lsp4j.jsonrpc.json.StreamMessageProducer.listen(StreamMessageProducer.java:94)
at org.eclipse.lsp4j.jsonrpc.json.ConcurrentMessageProcessor.run(ConcurrentMessageProcessor.java:99)
at java.util.concurrent.Executors$RunnableAdapter.call(Unknown Source)
at java.util.concurrent.FutureTask.run(Unknown Source)
at java.util.concurrent.ThreadPoolExecutor.runWorker(Unknown Source)
at java.util.concurrent.ThreadPoolExecutor$Worker.run(Unknown Source)
Caused by: java.lang.reflect.InvocationTargetException
at org.eclipse.lsp4j.jsonrpc.services.GenericEndpoint.lambda$null$0(GenericEndpoint.java:65)
... 11 more
Caused by: java.lang.IllegalStateException: This language server has already been initialized.
at org.eclipse.xtext.ide.server.LanguageServerImpl.initialize(LanguageServerImpl.java:225)
... 16 more
{"jsonrpc":"2.0","id":0,"error":{"code":-32603,"message":"Internal error.","data":"java.lang.RuntimeException: java.lang.reflect.InvocationTargetException\r\n\tat org.eclipse.lsp4j.jsonrpc.services.GenericEndpoint.lambda$null$0(GenericEndpoint.java:67)\r\n\tat org.eclipse.lsp4j.jsonrpc.services.GenericEndpoint.request(GenericEndpoint.java:120)\r\n\tat org.eclipse.lsp4j.jsonrpc.RemoteEndpoint.handleRequest(RemoteEndpoint.java:261)\r\n\tat org.eclipse.lsp4j.jsonrpc.RemoteEndpoint.consume(RemoteEndpoint.java:190)\r\n\tat org.eclipse.lsp4j.jsonrpc.json.StreamMessageProducer.handleMessage(StreamMessageProducer.java:192)\r\n\tat org.eclipse.lsp4j.jsonrpc.json.StreamMessageProducer.listen(StreamMessageProducer.java:94)\r\n\tat org.eclipse.lsp4j.jsonrpc.json.ConcurrentMessageProcessor.run(ConcurrentMessageProcessor.java:99)\r\n\tat java.util.concurrent.Executors$RunnableAdapter.call(Unknown Source)\r\n\tat java.util.concurrent.FutureTask.run(Unknown Source)\r\n\tat java.util.concurrent.ThreadPoolExecutor.runWorker(Unknown Source)\r\n\tat java.util.concurrent.ThreadPoolExecutor$Worker.run(Unknown Source)\r\n\tat java.lang.Thread.run(Unknown Source)\r\nCaused by: java.lang.reflect.InvocationTargetException\r\n\tat sun.reflect.NativeMethodAccessorImpl.invoke0(Native Method)\r\n\tat sun.reflect.NativeMethodAccessorImpl.invoke(Unknown Source)\r\n\tat sun.reflect.DelegatingMethodAccessorImpl.invoke(Unknown Source)\r\n\tat java.lang.reflect.Method.invoke(Unknown Source)\r\n\tat org.eclipse.lsp4j.jsonrpc.services.GenericEndpoint.lambda$null$0(GenericEndpoint.java:65)\r\n\t... 11 more\r\nCaused by: java.lang.IllegalStateException: This language server has already been initialized.\r\n\tat org.eclipse.xtext.ide.server.LanguageServerImpl.initialize(LanguageServerImpl.java:225)\r\n\t... 16 more\r\n"}}
message: {"jsonrpc":"2.0","id":1,"method":"shutdown","params":null}
{"jsonrpc":"2.0","id":1,"result":{}}
message: {"jsonrpc":"2.0","method":"exit","params":null}
Re: XText Web. How finds ACE the Language Server? [message #1799771 is a reply to message #1799770] |
Thu, 13 December 2018 11:24 |
Member |
I get this and then nothing happens on the editor
gogogo
start
open
Re: XText Web. How finds ACE the Language Server? [message #1799775 is a reply to message #1799774] |
Thu, 13 December 2018 12:10 |
everything should be mydsl. (thought that would be clear)
do you get any errors in client side console?
extensions: ['.mydsl'],
aliases: ['MYDSL', 'mydsl'],
mimetypes: ['application/mydsl']});
model: monaco.editor.createModel(value, 'mydsl', monaco.Uri.parse('inmemory://demo/model.mydsl')),
[Updated on: Thu, 13 December 2018 12:11] Report message to a moderator
Re: XText Web. How finds ACE the Language Server? [message #1799777 is a reply to message #1799775] |
Thu, 13 December 2018 12:22 |
Member |
much better. Whenever i press the keyboard, a message goes to the server. The Language consists of 'Hello'? This doesn't find autocomplete. Just the words which are already in the editor.
message: {"jsonrpc":"2.0","method":"textDocument/didChange","params":{"textDocument":{"uri":"inmemory://demo/model.mydsl","version":59},"contentChanges":[{"range":{"start":{"line":4,"character":0},"end":{"line":4,"character":1}},"rangeLength":1,"text":""}]}}
{"jsonrpc":"2.0","method":"textDocument/publishDiagnostics","params":{"uri":"inmemory://demo/model.mydsl","diagnostics":[{"range":{"start":{"line":0,"character":0},"end":{"line":0,"character":1}},"severity":1,"code":"org.eclipse.xtext.diagnostics.Diagnostic.Syntax","message":"missing EOF at \u0027{\u0027"}]}}
Re: XText Web. How finds ACE the Language Server? [message #1799778 is a reply to message #1799777] |
Thu, 13 December 2018 12:24 |
then there is still something wrong on your side that i cannot see.
i get this content assist answers
this is the request
message: {"jsonrpc":"2.0","id":4,"method":"textDocument/completion","params":{"textDocument":{"uri":"inmemory://demo/model.mydsl"},"position":{"line":3,"character":0},"context":{"triggerKind":1}}}
this is the response
{"jsonrpc":"2.0","id":4,"result":{"isIncomplete":true,"items":[{"label":"Hello","kind":14,"sortText":"00000","textEdit":{"range":{"start":{"line":3,"character":0},"end":{"line":3,"character":0}},"newText":"Hello"}},{"label":"New Greeting (Template with Choice)","kind":15,"sortText":"00001","insertTextFormat":2,"textEdit":{"range":{"start":{"line":3,"character":0},"end":{"line":3,"character":0}},"newText":"Hello ${1|A,B,C|} from ${2|A,B,you|}!"}},{"label":"New Greeting (Template with Placeholder)","kind":15,"sortText":"00002","insertTextFormat":2,"textEdit":{"range":{"start":{"line":3,"character":0},"end":{"line":3,"character":0}},"newText":"Hello ${1:name} from ${2:fromName}!"}}]}}
Re: XText Web. How finds ACE the Language Server? [message #1799779 is a reply to message #1799778] |
Thu, 13 December 2018 12:37 |
Member |
When I press 'H' within { }
I get this:
message: {"jsonrpc":"2.0","method":"textDocument/didChange","params":{"textDocument":{"uri":"inmemory://demo/model.mydsl","version":116},"contentChanges":[{"range":{"start":{"line":0,"character":1},"end":{"line":0,"character":1}},"rangeLength":0,"text":"H"}]}}
message: {"jsonrpc":"2.0","id":142,"method":"textDocument/completion","params":{"textDocument":{"uri":"inmemory://demo/model.mydsl"},"position":{"line":0,"character":2},"context":{"triggerKind":1}}}
{"jsonrpc":"2.0","id":142,"result":{"isIncomplete":true,"items":[]}}
message: {"jsonrpc":"2.0","id":143,"method":"textDocument/codeAction","params":{"textDocument":{"uri":"inmemory://demo/model.mydsl"},"range":{"start":{"line":0,"character":2},"end":{"line":0,"character":2}},"context":{"diagnostics":[]}}}
{"jsonrpc":"2.0","id":143,"result":[]}
message: {"jsonrpc":"2.0","id":144,"method":"textDocument/codeAction","params":{"textDocument":{"uri":"inmemory://demo/model.mydsl"},"range":{"start":{"line":0,"character":2},"end":{"line":0,"character":2}},"context":{"diagnostics":[]}}}
{"jsonrpc":"2.0","id":144,"result":[]}
Current Time: Fri Apr 26 18:59:16 GMT 2024
Powered by FUDForum. Page generated in 0.07263 seconds
