Home » Modeling » GMF (Graphical Modeling Framework) » Customizing GMF Diagram + Palette(Correct way to construct another diagram)
Customizing GMF Diagram + Palette [message #1796156] Sun, 07 October 2018 07:44
Hi there,
I've been looking through all the files generated by EMF and I noticed a couple of things:
- The Canvas to be constructed is included in .gmfgraph
- The Palette to be used is located in .gmftool
- The Diagram to be constructed is in .gmfgen
The thing is the options to add a new Diagram or a new Canvas are disabled. I also wanted to customize the Palette Standard Group (which contains Selection, Zoom In, Zoom Out, Notes) with a new button. This button would have the feature to navigate to the other diagram.
In resume, when launching the Eclipse EMF Application and by adding a new A.Diagram, 3 files would have to be generated:
default.A (which contains the different views: Selection, Parent, List, Tree, Table, Tree with Columns - Metamodel A)
default.A_diagram (GMF Editor - Metamodel A)
default.A_newDiagram (GMF Editor - Metamodel A)
default.A_diagram should be able to navigate to default.A_newDiagram and vice-versa.
The reason I want to do this is to choose some model elements on the new diagram that would perform some operations on the other diagram and highlight them.
Can I get some ideas from you guys? Maybe I described quite a complex task here, instead of separating it by smaller parts.
Thanks in advance
Previous Topic:GMF Editor
Next Topic:GMF Transformation *.gmfmap to *.gmfgen fails
Current Time: Mon Oct 27 06:29:07 EDT 2025
Powered by FUDForum. Page generated in 0.02271 seconds
