Home » Archived » BIRT » BIRT table column only has value for the first entry(BIRT only show data for the first row entry of a column)
BIRT table column only has value for the first entry [message #1796083] Thu, 04 October 2018 14:55 Go to next message
In a BIRT report I am working on, one column of the table has this expression:
if(params["Stub"] == "FE") dataSetRow["FieldEconomist"];
else if (params["Stub"] == "Sample") dataSetRow["Sample"];
else if (params["Stub"] == "NAICSHS") dataSetRow["NAICSHS"];
else " ";
When I run the report, only the first row entry of that column is populated with data. I cannot figure out what is wrong yet.
Re: BIRT table column only has value for the first entry [message #1796431 is a reply to message #1796083] Fri, 12 October 2018 16:49 Go to previous message
There is not enough info to really help you. What is the trigger for the expression? Putting it in the column or cell is going to make it execute the code for every line. I think you would be better off either putting the code in a global variable or as a computed column.
Previous Topic:"Can not open the report archive" because of "IOException"
Next Topic:Get file last modification date
Current Time: Wed Oct 15 15:38:00 EDT 2025
Powered by FUDForum. Page generated in 0.03148 seconds
