Re: .aird can not be loaded [message #1795862 is a reply to message #1795859] |
Mon, 01 October 2018 13:20 |
Last Sirius migration version is: 12.1.2.201804131029
This part indicates you are probably running a version 5.1.x of Sirius.
Representation version is: 13.0.0.201804031646
This one indicates the model has alread been opened and saved using Sirius 6.0.
When you open a Sirius model which was created using an earlier version, Sirius automatically migrates it to the current version. Of course this can not work in the other way: versions of Sirius from the past can not know how to correctly interpret models which have been created by versions from their future. Allowing this can cause all kinds of difficult to understand bugs and model corruptions, hence the message. So from the message, you're using Sirius 5.1.2 to try to load a model which has already been opened using Sirius 6.0 and thus migrated to the "Sirius 6.0" format.
The simplest solution is to upgrade to Sirius 6.0, which will know how to correctly interpret models in version "13.0.0". If that's not possible, you can try to lie and hope that things will work out: open the aird file as text, and in the "version" attribute of the top-level viewpoint:DAnalysis XML element, change the version to 12.1.2.201804131029, but there is no guarantee that this will not trigger strange bugs down the road.
Pierre-Charles David - Obeo
FUDForum. Page generated in 0.03051 seconds
