Home » Modeling » TMF (Xtext) » JAVA HEAP SPACE (OUT OF MEMEORY)(For large and many resources (1000 files) out of memory)
JAVA HEAP SPACE (OUT OF MEMEORY) [message #1795550] Tue, 25 September 2018 04:38 Go to next message
I get the below error, when I have more than 1000 files and I am trying to build project. Works well, when I have less files in project.
I am using Xtext 2.13.
Any suggestion that what is going wrong ?
java.lang.OutOfMemoryError: Java heap space
	at java.lang.AbstractStringBuilder.<init>(Unknown Source)
	at java.lang.StringBuilder.<init>(Unknown Source)
	at org.eclipse.xtext.parser.antlr.XtextTokenStream.toString(XtextTokenStream.java:81)
	at org.antlr.runtime.CommonTokenStream.toString(CommonTokenStream.java:352)
	at org.eclipse.xtext.parser.antlr.AbstractInternalAntlrParser.parse(AbstractInternalAntlrParser.java:548)
	at org.eclipse.xtext.parser.antlr.AbstractAntlrParser.doParse(AbstractAntlrParser.java:102)
	at org.eclipse.xtext.parser.antlr.AbstractAntlrParser.parse(AbstractAntlrParser.java:84)
	at org.eclipse.xtext.parser.antlr.AbstractAntlrParser.doParse(AbstractAntlrParser.java:62)
	at org.eclipse.xtext.parser.AbstractParser.parse(AbstractParser.java:33)
	at org.eclipse.xtext.resource.XtextResource.doLoad(XtextResource.java:176)
	at org.eclipse.xtext.linking.lazy.LazyLinkingResource.doLoad(LazyLinkingResource.java:100)
	at org.eclipse.emf.ecore.resource.impl.ResourceImpl.load(ResourceImpl.java:1518)
	at org.eclipse.emf.ecore.resource.impl.ResourceImpl.load(ResourceImpl.java:1297)
	at org.eclipse.emf.ecore.resource.impl.ResourceSetImpl.demandLoad(ResourceSetImpl.java:259)
	at org.eclipse.emf.ecore.resource.impl.ResourceSetImpl.demandLoadHelper(ResourceSetImpl.java:274)
	at org.eclipse.xtext.resource.XtextResourceSet.getResource(XtextResourceSet.java:265)
	at org.eclipse.xtext.resource.SynchronizedXtextResourceSet.getResource(SynchronizedXtextResourceSet.java:25)
	at org.eclipse.xtext.builder.resourceloader.SerialResourceLoader$1.next(SerialResourceLoader.java:47)
	at org.eclipse.xtext.builder.resourceloader.AbstractResourceLoader$CheckedLoadOperation.next(AbstractResourceLoader.java:77)
	at org.eclipse.xtext.builder.clustering.ClusteringBuilderState.writeNewResourceDescriptions(ClusteringBuilderState.java:382)
	at org.eclipse.xtext.builder.clustering.ClusteringBuilderState.doUpdate(ClusteringBuilderState.java:135)
	at org.eclipse.xtext.builder.builderState.AbstractBuilderState.update(AbstractBuilderState.java:116)
	at org.eclipse.xtext.builder.impl.XtextBuilder.doBuild(XtextBuilder.java:287)
	at org.eclipse.xtext.builder.impl.XtextBuilder.incrementalBuild(XtextBuilder.java:267)
	at org.eclipse.xtext.builder.impl.XtextBuilder.build(XtextBuilder.java:161)
	at org.eclipse.core.internal.events.BuildManager$2.run(BuildManager.java:735)
	at org.eclipse.core.internal.events.BuildManager.basicBuild(BuildManager.java:206)
	at org.eclipse.core.internal.events.BuildManager.basicBuild(BuildManager.java:246)
	at org.eclipse.core.internal.events.BuildManager$1.run(BuildManager.java:301)
	at org.eclipse.core.internal.events.BuildManager.basicBuild(BuildManager.java:304)
Thanks and regards,
Virag Purnam
Re: JAVA HEAP SPACE (OUT OF MEMEORY) [message #1795551 is a reply to message #1795550] Tue, 25 September 2018 04:41 Go to previous messageGo to next message
this is expected behaviour. memory is not a infinite resource.
you can increase memory (-Xmx) or enable resource clustering (bind org.eclipse.xtext.resource.clustering.DynamicResourceClusteringPolicy as org.eclipse.xtext.resource.clustering.IResourceClusteringPolicy via overridingGuiceModule and ui module - this might lead to much longer build times)
[Updated on: Tue, 25 September 2018 04:42] by Moderator
Re: JAVA HEAP SPACE (OUT OF MEMEORY) [message #1795552 is a reply to message #1795551] Tue, 25 September 2018 04:50 Go to previous messageGo to next message
Thanks for the reply.
Will this solve problem at customer's end?
Because they might have another project with 2000 files.
And If you can share example for how to bind DynamicResourceClusteringPolicy, this will help me.
Re: JAVA HEAP SPACE (OUT OF MEMEORY) [message #1795554 is a reply to message #1795550] Tue, 25 September 2018 04:59 Go to previous messageGo to next message
2000 files are quite some, but nothing Xtext could not handle. How large do the files get?
Anyway, Christian's hints are the right one to start with.
Re: JAVA HEAP SPACE (OUT OF MEMEORY) [message #1795558 is a reply to message #1795554] Tue, 25 September 2018 05:15 Go to previous messageGo to next message
Thanks and I agree with you.
Is the below code snippet is correct way to bind DynamicResourceClusteringPolicy?
public class MyModule implements Module {
	public MyModule() {
		// TODO Auto-generated constructor stub
	public void configure(Binder binder) {
		binder.bind(IResourceClusteringPolicy.class).to(DynamicResourceClusteringPolicy.class);
Re: JAVA HEAP SPACE (OUT OF MEMEORY) [message #1795573 is a reply to message #1795558] Tue, 25 September 2018 08:06 Go to previous messageGo to next message
Yes. Use that with the override. Guice module extension point
Re: JAVA HEAP SPACE (OUT OF MEMEORY) [message #1795606 is a reply to message #1795573] Wed, 26 September 2018 04:13 Go to previous messageGo to next message
After adding DynamicResourceClusteringPolicy to UiModule, I started getting below exception in Activator class.
Failed to create injector for org.xtext.example.mydsl.MyDsl
1) No implementation for org.eclipse.xtext.builder.resourceloader.IResourceLoader annotated with @com.google.inject.name.Named(value=org.eclipse.xtext.builder.resourceloader.crossLinking) was bound.
  while locating org.eclipse.xtext.builder.resourceloader.IResourceLoader annotated with @com.google.inject.name.Named(value=org.eclipse.xtext.builder.resourceloader.crossLinking)
    for field at org.eclipse.xtext.builder.clustering.ClusteringBuilderState.crossLinkingResourceLoader(Unknown Source)
  at org.eclipse.xtext.service.MethodBasedModule.configure(MethodBasedModule.java:57)
2) No implementation for org.eclipse.xtext.builder.resourceloader.IResourceLoader annotated with @com.google.inject.name.Named(value=org.eclipse.xtext.builder.resourceloader.globalIndex) was bound.
  while locating org.eclipse.xtext.builder.resourceloader.IResourceLoader annotated with @com.google.inject.name.Named(value=org.eclipse.xtext.builder.resourceloader.globalIndex)
    for field at org.eclipse.xtext.builder.clustering.ClusteringBuilderState.globalIndexResourceLoader(Unknown Source)
Help needed here?
Not sure what is going wrong?
Re: JAVA HEAP SPACE (OUT OF MEMEORY) [message #1795611 is a reply to message #1795606] Wed, 26 September 2018 04:25 Go to previous messageGo to next message
what did you exactly do?
i assume you simply did the same configure which is a bad idea when not calling super.
a terrible terrible bad idea.
in Xtext runtime and ui module such a binding would ususally look like
def Class<? extends IResourceClusteringPolicy> bindIResourceClusteringPolicy() {
return DynamicResourceClusteringPolicy
or
def void configureIResourceClusteringPolicy(Binder binder) {
binder.bind(IResourceClusteringPolicy).to(DynamicResourceClusteringPolicy)
please read the docs on dependency injection
[Updated on: Wed, 26 September 2018 04:29] by Moderator
Re: JAVA HEAP SPACE (OUT OF MEMEORY) [message #1795615 is a reply to message #1795611] Wed, 26 September 2018 04:48 Go to previous messageGo to next message
Ok.. I have done the below mentioned changes.
New Module:
	public MyModule() {
plugin.xml
<extension point="org.eclipse.xtext.ui.shared.overridingGuiceModule">
    	<module
        	class="org.xtext.example.mydsl.ui.MyModule">
    	</module>
    </extension>
MyDslUiModule.xtend
Am I doing it correct?
Re: JAVA HEAP SPACE (OUT OF MEMEORY) [message #1795619 is a reply to message #1795615] Wed, 26 September 2018 05:01 Go to previous messageGo to next message
Yes it looks ok, does it work?
Re: JAVA HEAP SPACE (OUT OF MEMEORY) [message #1795622 is a reply to message #1795619] Wed, 26 September 2018 05:17 Go to previous messageGo to next message
Yeah this works good.
I have done similar thing for ClusteringBuilderState. That was creating problem.
Can't we do same for ClusteringBuilderState? Like below.
	public MyModule() {
		binder.bind(ClusteringBuilderState.class).to(MyClusteringBuilderState.class);
    	<module
    	</module>
    </extension>
	def Class<? extends ClusteringBuilderState> bindClusteringBuilderState() {
		return MyClusteringBuilderState
Why its is not working for ClusteringBuilderState? I want to modify this class.
Re: JAVA HEAP SPACE (OUT OF MEMEORY) [message #1795624 is a reply to message #1795622] Wed, 26 September 2018 05:21 Go to previous messageGo to next message
cause clustering builder state is shared. => you have to do it with MyModule and it will affect all dsls
Re: JAVA HEAP SPACE (OUT OF MEMEORY) [message #1795627 is a reply to message #1795624] Wed, 26 September 2018 05:26 Go to previous message
Ok.
That means I dont have to add it to UiModule.
Just below line will do the job incase of ClusteringBuilderState.
	public MyModule() {
Thanks a lot. :) It was really helpful.
[Updated on: Wed, 26 September 2018 05:31] by Moderator
Previous Topic:How to implement scoping and validation for an element at same time
Next Topic:How to implement scoping and validation for an element at same time
Current Time: Wed Oct 29 02:54:29 EDT 2025
Powered by FUDForum. Page generated in 0.69384 seconds
