xtext-eclipse project [message #1795430] |
Fri, 21 September 2018 18:08 |
Aniruddh Chaturvedi Messages: 2 Registered: September 2018 |
I am trying to build the xtext-eclipse project. I did "mvn clean install" as suggested in the readme of the project and am getting the following error:
[ERROR] Cannot resolve target definition:
[ERROR] Software being installed: org.eclipse.xtext.common.types 2.16.0.v20180918-0912
[ERROR] Missing requirement: org.eclipse.xtext.common.types 2.16.0.v20180918-0912 requires 'osgi.bundle; org.objectweb.asm [6.2.1,6.3.0)' but it could not be found
[ERROR]
[ERROR] Failed to resolve target definition /Users/aniruddh/Documents/xtextFork/xtext-eclipse/releng/org.eclipse.xtext.target/org.eclipse.xtext.target-oxygen.target: See log for details -> [Help 1]
[ERROR]
[ERROR] To see the full stack trace of the errors, re-run Maven with the -e switch.
[ERROR] Re-run Maven using the -X switch to enable full debug logging.
[ERROR]
[ERROR] For more information about the errors and possible solutions, please read the following article
Also, I am trying to build xtext locally.
So, can someone tell me, in what sequence should I build these projects:
xtext-core: The core framework, Language Server support
xtext-lib: Libraries for Xbase and Xtend
xtext-extras: Additional editor-independent features, mostly Java support
xtext-eclipse: Plug-ins for Eclipse
xtext-web: Support for Orion, Ace and CodeMirror
xtext-maven: Support for Maven
xtext-xtend: The Xtend language
xtext-umbrella: Common Eclipse features and P2 update sites
FUDForum. Page generated in 0.03647 seconds
