| Build Problems with Xtend Maven Plugin (signer information) [message #1795154] |
Mon, 17 September 2018 06:52  |
We currently run into problems with the Xtend Maven Plugin. On Friday (2018-09-14) our build was able to complete successfully, while today (2018-09-17) the same build fails with the following error:
[ERROR] Failed to execute goal org.eclipse.xtend:xtend-maven-plugin:2.7.3:compile (default) on project XXX: Execution default of goal org.eclipse.xtend:xtend-maven-plugin:2.7.3:compile failed: Unable to load the mojo 'compile' (or one of its required components) from the plugin 'org.eclipse.xtend:xtend-maven-plugin:2.7.3': com.google.inject.ProvisionException: Unable to provision, see the following errors:
[ERROR]
[ERROR] 1) Error injecting constructor, com.google.inject.internal.util.$ComputationException: com.google.inject.internal.util.$ComputationException: com.google.inject.internal.util.$ComputationException: com.google.inject.internal.util.$ComputationException: com.google.inject.internal.util.$ComputationException: com.google.inject.internal.util.$ComputationException: java.lang.SecurityException: class "org.eclipse.core.runtime.OperationCanceledException"'s signer information does not match signer information of other classes in the same package
[ERROR] at org.eclipse.xtend.maven.XtendCompile.<init>(XtendCompile.java:28)
[ERROR] while locating org.eclipse.xtend.maven.XtendCompile
[ERROR] at ClassRealm[plugin>org.eclipse.xtend:xtend-maven-plugin:2.7.3, parent: sun.misc.Launcher$AppClassLoader@5c647e05] (via modules: org.eclipse.sisu.wire.WireModule -> org.eclipse.sisu.plexus.PlexusBindingModule)
[ERROR] while locating org.apache.maven.plugin.Mojo annotated with @com.google.inject.name.Named(value=org.eclipse.xtend:xtend-maven-plugin:2.7.3:compile)
Is there a workaround for this problem or will it be fixed soon? If you prefer I could also open a bug report.
FUDForum. Page generated in 0.05457 seconds
