Home » Eclipse Projects » Eclipse Titan » Unified Diagnostic Services (UDS) ISO 14229 decoder / encoder(Unified Diagnostic Services RAW encoder / decoder)
Unified Diagnostic Services (UDS) ISO 14229 decoder / encoder [message #1794920] |
Tue, 11 September 2018 02:43  |
I have created a subset of the Unified Diagnostic Services (UDS) ISO 14229.
type enumerated SuppressPosRspMsgIndicationBitType {
doNotsuppresssPos (0),
suppresssPos (1)
with {variant "FIELDLENGTH(1)"}
type OCT1 DiagnosticSessionType
type record DefaultSessionRequest {
DiagnosticSessionType diagnosticSessionType ('01'O)
} with { variant "" };
type record ProgrammingSessionRequest {
DiagnosticSessionType diagnosticSessionType ('02'O)
type record ExtendedDiagnosticSessionRequest {
DiagnosticSessionType diagnosticSessionType ('03'O)
type record SafetySystemDiagnosticSessionRequest {
DiagnosticSessionType diagnosticSessionType ('04'O)
type union DiagnosticSessionRequestType
DefaultSessionRequest defaultSession,
ProgrammingSessionRequest programmingSession,
ExtendedDiagnosticSessionRequest extendedDiagnosticSession,
SafetySystemDiagnosticSessionRequest safetySystemDiagnosticSession
with {variant "TAG (
defaultSession, diagnosticSessionType = '01'O;
programmingSession, diagnosticSessionType = '02'O;
extendedDiagnosticSession, diagnosticSessionType = '03'O;
safetySystemDiagnosticSession, diagnosticSessionType = '04'O)";
variant "FIELDLENGTH(7)"
type record DiagnosticSessionControlRequestSID
SID sid ('10'O),
SuppressPosRspMsgIndicationBitType suppressPosRspMsgIndicationBit,
DiagnosticSessionRequestType diagnosticSessionType
} with { variant "FIELDORDER(msb)" };
type record TesterPresentRequestSID
SID sid ('3E'O),
BIT7 zero ('0000000'B)
The SuppressPosRspMsgIndicationBitType (1 bit) forms together with the following 7 bit type when encoding / decoding a Byte. That's why I have defined DiagnosticSessionRequestType as FIELDLENGTH(7).
When encoding / decoding DiagnosticSessionRequestType encodes to a 3 byte value instead of the expected 2 byte value '1083'O and decodes even to a differnt than the encoded value (after decoding the suppressPosRspMsgIndicationBit changes from suppresssPos to doNotsuppresssPos):
MTC@Donald: encode_TopLevelMessage_UDS_requests(): Encoding @UnifiedDiagnosticServices.TopLevelMessage_UDS_requests: { diagnosticSessionControlRequestSID := { sid := '10'O, suppressPosRspMsgIndicationBit := suppresssPos (1), diagnosticSessionType := { extendedDiagnosticSession := { diagnosticSessionType := '03'O } } } }
MTC@Donald: encode_TopLevelMessage_UDS_requests(): Stream after encoding: '100600'O
MTC@Donald: '100600'O
MTC@Donald: decode_TopLevelMessage_UDS_requests(): Stream before decoding: '100600'O
MTC@Donald: decode_TopLevelMessage_UDS_requests(): Decoded @UnifiedDiagnosticServices.TopLevelMessage_UDS_requests: { diagnosticSessionControlRequestSID := { sid := '10'O, suppressPosRspMsgIndicationBit := doNotsuppresssPos (0), diagnosticSessionType := { extendedDiagnosticSession := { diagnosticSessionType := '03'O } } } }
MTC@Donald: { diagnosticSessionControlRequestSID := { sid := '10'O, suppressPosRspMsgIndicationBit := doNotsuppresssPos (0), diagnosticSessionType := { extendedDiagnosticSession := { diagnosticSessionType := '03'O } } } }
TesterPresentRequestSID with the paramter suppresssPos (1) encodes to '3E80'O, what it should:
MTC@Donald: encode_TopLevelMessage_UDS_requests(): Encoding @UnifiedDiagnosticServices.TopLevelMessage_UDS_requests: { testerPresentRequestSID := { sid := '3E'O (">"), suppressPosRspMsgIndicationBit := suppresssPos (1), zero := '0000000'B } }
MTC@Donald: encode_TopLevelMessage_UDS_requests(): Stream after encoding: '3E80'O
MTC@Donald: '3E80'O
MTC@Donald: decode_TopLevelMessage_UDS_requests(): Stream before decoding: '3E80'O
MTC@Donald: decode_TopLevelMessage_UDS_requests(): Decoded @UnifiedDiagnosticServices.TopLevelMessage_UDS_requests: { testerPresentRequestSID := { sid := '3E'O (">"), suppressPosRspMsgIndicationBit := suppresssPos (1), zero := '0000000'B } }
MTC@Donald: { testerPresentRequestSID := { sid := '3E'O (">"), suppressPosRspMsgIndicationBit := suppresssPos (1), zero := '0000000'B } }
Is it necessary to change the DiagnosticSessionRequestType to:
type BIT7 DiagnosticSessionType
DiagnosticSessionType diagnosticSessionType ('0000001'B)
DiagnosticSessionType diagnosticSessionType ('0000010'B)
DiagnosticSessionType diagnosticSessionType ('0000011'B)
DiagnosticSessionType diagnosticSessionType ('0000100'B)
defaultSession, diagnosticSessionType = '0000001'B;
programmingSession, diagnosticSessionType = '0000010'B;
extendedDiagnosticSession, diagnosticSessionType = '0000011'B;
safetySystemDiagnosticSession, diagnosticSessionType = '0000100'B)";
Re: Unified Diagnostic Services (UDS) ISO 14229 decoder / encoder [message #1794986 is a reply to message #1794920] |
Wed, 12 September 2018 04:59  |
for the second issue: the attribute 'FIELDORDER(msb)' does not extend to lower level records/sets. Because of this the 1 bit for the enumerated type is encoded as the MSB in the octet, and the 7 bits in the ...SessionRequest records are encoded with LSB first (thus overwriting the enum's bit).
This is an undocumented limitation of the attribute FIELDORDER.
To fix this you'd need to add the attribute 'FIELDORDER(msb)' to the ...SessionRequest records.
Like this:
RequestDiagnosticSessionType diagnosticSessionType ('0000001'B)
RequestDiagnosticSessionType diagnosticSessionType ('0000010'B)
RequestDiagnosticSessionType diagnosticSessionType ('0000011'B)
RequestDiagnosticSessionType diagnosticSessionType ('0000100'B)
Botond Baranyi
Current Time: Mon Sep 22 05:09:58 EDT 2025
Powered by FUDForum. Page generated in 0.05104 seconds
