javafx-swt.jar not in the classpath when using java10 [message #1794899] |
Mon, 10 September 2018 11:52  |
I have an eclipse plugin that uses FXCanvas and javafx-swt.
This works fine with java 8 (pointing to lib/javafxswt.jar) and with java 9 (pointing to javafx-swt.jar)
but it doesn't work with java 10. (even if javafx-swt.jar is present in /usr/lib/jvm/java-10-oracle/lib )
Is there an update of Efxclipse that fixes that ? (I use efxclipse 3.3.0.20180528 bundled with photon)
This is quite annoying because, unfortunately there is no way to download java 9 anymore, only java 10.
next question, will java 11 (which is planned for the end of the month) be also supported ?
Didier
FUDForum. Page generated in 0.03517 seconds
