Re: Define Selection Wizard Programmatically [message #1794107 is a reply to message #1794099] |
Thu, 23 August 2018 15:29 |
In fact, it is the same wizard widget as can be defined in the properties view[1]. For instance, you will need to define at least a page[2] in this wizard. As this wizard operation, is triggered from a Selection Wizard, you will need to use the variables provided by the Selection Wizard to specify the Wizard operation. For instance, the "var:element" expression provided by the Selection Wizard will return a list of element selected in the Selection Wizard and will be needed for the "Semantic Candidate Expression" of the page of the wizard operation.
Steve
[1] https://www.eclipse.org/sirius/doc/specifier/properties/Properties_View_Description.html
[2] https://www.eclipse.org/sirius/doc/specifier/properties/Properties_View_Description.html#pages
Steve Monnier - Obeo Canada
FUDForum. Page generated in 0.03166 seconds
