Re: Upgrading Oomph on Ubuntu 18.04 [message #1794507 is a reply to message #1794502] |
Fri, 31 August 2018 15:05 |
Ed Merks Messages: 33142 Registered: July 2009 |
Yes, I was able to reproduce it on Windows as well, in debug mode, forcing the certificates to be unrecognized by changing the underlying data structures. Missing certificates is a JDK problem, but as you say, of course the code should be tolerant of that. In an ideal world, all possible code paths would be tested, but the world is never ideal and this certificate prompt during self-update clearly wan't tested so of course there is no code to give error information about it...
I have no basis for saying the Oracle JDK is better nor do I suggest you switch, unless repeated prompts for certificates when updating becomes annoying; this will happen in the IDE as well, when you update, and whenever you install. In fact it will happen with anything that processes/verifies signatures. In any case, the latest version of the installer, which will also be distributed as part of the 2018-09 release in September, will not have a problem updating anymore. The older version unfortunately can't be fixed by updating in a root-certificate-deprived environment.
Ed Merks
FUDForum. Page generated in 0.04640 seconds
