Home » Newcomers » Newcomers » Starting Tomcat v9 at localhost has encountered a problem
Starting Tomcat v9 at localhost has encountered a problem [message #1793827] Thu, 16 August 2018 10:52
Several ports (8005, 8080, 8009) required by Tomcat v9.0 Server at localhost are already in use. The server may already be running in another process, or a system process may be using the port. To start this server you will need to stop the other process or change the port number(s).
I've recently installed TeamSQL, PostGreSQL(shouldn't affect it anyways), and added the latest safe version of Spring to eclipse. I've uninstalled both SQL programs so I'm left thinking this is a Spring problem?
Is there a way to remove all of Spring with just one click or do I have to remove all parts of it individually? Anything I should try first?
It was working fine a week or so ago.
Open to other suggestions, I'm fairly new to this environment.
Previous Topic:My Ecliplse often stop
Next Topic:eclipse - yocto build
Current Time: Wed Nov 05 07:46:47 EST 2025
Powered by FUDForum. Page generated in 0.10247 seconds
