Home » Newcomers » Newcomers » eclipse cannot recognize ${spring.version} in pom.xml properties, which lead to dependies fail(maven pom properties)
eclipse cannot recognize ${spring.version} in pom.xml properties, which lead to dependies fail [message #1792624] Fri, 20 July 2018 10:18 Go to next message
Jerry zhou is currently offline Jerry zhouFriend
i can run "mvn clean package" successfuly in command line.
after i import this project into eclipse as maven project, and launch debug, i got the fail:
The archive: /home/see/.m2/repository/org/springframework/spring-webmvc/${spring.version}/spring-webmvc-${spring.version}.jar which is referenced by the classpath, does not exist.
In my pom.xml file:
<properties>
<spring.version>4.2.1.RELEASE</spring.version>
</properties>
<dependency>
<groupId>org.springframework</groupId>
<artifactId>spring-webmvc</artifactId>
<version>${spring.version}</version>
</dependency>
how can i make eclipse recognize the properties in pom.xml file.
Re: eclipse cannot recognize ${spring.version} in pom.xml properties, which lead to dependies fail [message #1792877 is a reply to message #1792624] Wed, 25 July 2018 10:34 Go to previous messageGo to next message
Do I have to edit the project's .classpath file manually?
Re: eclipse cannot recognize ${spring.version} in pom.xml properties, which lead to dependies fail [message #1792879 is a reply to message #1792877] Wed, 25 July 2018 10:41 Go to previous messageGo to next message
Jerry zhou wrote on Wed, 25 July 2018 10:34
It can't works, my modifies are replaced automatically, because the .classpath file, will be updated by eclipse,
Re: eclipse cannot recognize ${spring.version} in pom.xml properties, which lead to dependies fail [message #1792984 is a reply to message #1792879] Fri, 27 July 2018 03:43 Go to previous message
Jerry zhou wrote on Wed, 25 July 2018 10:41
OK, this problem has been resloved~
after I delete the project from eclipse, and delete all eclipse related project file: .classpath ...;
import the project again, the .classpath file was changed, these content dispear:
         <classpathentry kind="var" path="TOMCAT_HOME/lib/servlet-api.jar"/>
	<classpathentry kind="var" path="TOMCAT_HOME/lib/jasper.jar"/>
	<classpathentry kind="var" path="TOMCAT_HOME/lib/jsp-api.jar"/>
	<classpathentry kind="var" path="TOMCAT_HOME/lib/el-api.jar"/>
	<classpathentry kind="var" path="TOMCAT_HOME/lib/annotations-api.jar"/>
	<classpathentry exported="true" kind="var" path="M2_REPO/org/springframework/spring-webmvc/${spring.version}/spring-webmvc-${spring.version}.jar"/>
	<classpathentry exported="true" kind="var" path="M2_REPO/org/springframework/spring-tx/${spring.version}/spring-tx-${spring.version}.jar"/>
	<classpathentry exported="true" kind="var" path="M2_REPO/org/aspectj/aspectjweaver/${aspectjweaver.version}/aspectjweaver-${aspectjweaver.version}.jar"/>
[Updated on: Fri, 27 July 2018 03:46]
Report message to a moderator
Previous Topic:Test OM2M
Next Topic:eclipse Gprof timing not shows
Current Time: Wed Mar 29 13:57:16 GMT 2023
Powered by FUDForum. Page generated in 0.03364 seconds
