Creating EXPRESS G files with JSDAI [message #1792585] |
Thu, 19 July 2018 17:42  |
Hello
I'm running ECLIPSE JSDAI on Windows 10 (Eclipse IDE for Java Developers
Version: Oxygen.3a Release (4.7.3a) Build id: 20180405-1200).
I'ved created an EXPRESS P (Perspective) file (from ISO 82045 example).
When I compile there are no errors.
I've an ouput file in .exd (it seems that the Dictionnary is created).
Also I've a .jar and a .src.jar created in the root folder.
I can create an .exg (graphical) or an outline file. When I open the .exg file I've got an error : An error has occurred. See error log for more details.
Here what I've got on the console :
file C:\Users\Christian_D\eclipse-workspace\IES_802045\Express files\_exclude not found.
JSDAI(TM) Express Compiler, Copyright (C) 1998-2011 LKSoftWare GmbH
version 4.3.2, build 500, 2011-12-13
Complex generator is running
Complex generator ended
Java backend is running
Java backend ended
Express Compiler ended
--- End of Express Compiler Output ---
express compilation time: 1 seconds
java compilation time: 2 seconds
--- Express Compiler Output ---
Who had experienced this ?
Thank you for your help.
FUDForum. Page generated in 0.05743 seconds
