Re: Issue while creating the child node in tree description in eclipse sirius [message #1792858 is a reply to message #1792525] |
Wed, 25 July 2018 08:32 |
Quote:The issue is when we create new child man it will create man node inside as a child node but it will not affect the diagram.
Are your that when adding a new man in your tree representation, the model is also modified? save the changes and open the family model with the default model editor to make sure the changes are properly persisted.
Is your diagram synchronized? (right click "unsynchronized" is unchecked) or your representations are in automatic refresh? (Window > Preferences > Sirius > Automatic Refresh)
Quote:If we use create man inside family tree tool it makes changes in diagram description but the node will not create as child node it will get created at the end.
I'm not sure to understand this part. You talk about diagram description, which is the definition of the diagram in the odesign file.
Florian
FUDForum. Page generated in 0.02809 seconds
