| Upgrading BIRT runtime from 4.5 to BIRT runtime 4.8 [message #1792479] |
Wed, 18 July 2018 08:51 |
Below are the logs while generating the pdf from war file:
org.eclipse.birt.data.engine.odaconsumer.Driver doGetDriverManifest
SEVERE: Cannot find or process the ODA data source extension configuration.
java.lang.IllegalArgumentException: Cannot find the ODA dataSource extension (org.eclipse.datatools.enablement.oda.xml).
Check the workspace log file for any problems with loading the extension bundle and its dependencies.
at org.eclipse.datatools.connectivity.oda.util.manifest.ManifestExplorer.getExtensionManifest(ManifestExplorer.java:200)
at org.eclipse.birt.data.engine.odaconsumer.Driver.doGetDriverManifest(Driver.java:152)
at org.eclipse.birt.data.engine.odaconsumer.Driver.findDataSourceExtensionConfig(Driver.java:128)
at org.eclipse.birt.data.engine.odaconsumer.Driver.getDriverExtensionConfig(Driver.java:79)
at org.eclipse.birt.data.engine.odaconsumer.Driver.getExtensionConfig(Driver.java:61)
at org.eclipse.birt.data.engine.odaconsumer.Driver.createNewDriverHelper(Driver.java:99)
at org.eclipse.birt.data.engine.odaconsumer.DriverManager.getDriverHelper(DriverManager.java:115)
at org.eclipse.birt.data.engine.odaconsumer.DriverManager.getNewDriverHelper(DriverManager.java:101)
at org.eclipse.birt.data.engine.odaconsumer.ConnectionManager.openConnection(ConnectionManager.java:150)
at org.eclipse.birt.data.engine.executor.DataSource.newConnection(DataSource.java:224)
at org.eclipse.birt.data.engine.executor.DataSource.open(DataSource.java:212)
at org.eclipse.birt.data.engine.impl.DataSourceRuntime.openOdiDataSource(DataSourceRuntime.java:217)
at org.eclipse.birt.data.engine.impl.QueryExecutor.openDataSource(QueryExecutor.java:439)
at org.eclipse.birt.data.engine.impl.QueryExecutor.prepareExecution(QueryExecutor.java:327)
at org.eclipse.birt.data.engine.impl.PreparedQuery.doPrepare(PreparedQuery.java:464)
at org.eclipse.birt.data.engine.impl.PreparedDataSourceQuery.produceQueryResults(PreparedDataSourceQuery.java:190)
at org.eclipse.birt.data.engine.impl.PreparedDataSourceQuery.execute(PreparedDataSourceQuery.java:178)
at org.eclipse.birt.data.engine.impl.PreparedOdaDSQuery.execute(PreparedOdaDSQuery.java:179)
at org.eclipse.birt.report.data.adapter.impl.DataRequestSessionImpl.execute(DataRequestSessionImpl.java:652)
at org.eclipse.birt.report.engine.data.dte.DteDataEngine.doExecuteQuery(DteDataEngine.java:152)
at org.eclipse.birt.report.engine.data.dte.AbstractDataEngine.execute(AbstractDataEngine.java:286)
at org.eclipse.birt.report.engine.executor.ExecutionContext.executeQuery(ExecutionContext.java:1954)
at org.eclipse.birt.report.engine.executor.QueryItemExecutor.executeQuery(QueryItemExecutor.java:80)
at org.eclipse.birt.report.engine.executor.DataItemExecutor.execute(DataItemExecutor.java:75)
at org.eclipse.birt.report.engine.internal.executor.dup.SuppressDuplicateItemExecutor.execute(SuppressDuplicateItemExecutor.java:43)
at org.eclipse.birt.report.engine.internal.executor.wrap.WrappedReportItemExecutor.execute(WrappedReportItemExecutor.java:46)
at org.eclipse.birt.report.engine.internal.executor.l18n.LocalizedReportItemExecutor.execute(LocalizedReportItemExecutor.java:34)
at org.eclipse.birt.report.engine.layout.html.HTMLBlockStackingLM.layoutNodes(HTMLBlockStackingLM.java:65)
at org.eclipse.birt.report.engine.layout.html.HTMLStackingLM.layoutChildren(HTMLStackingLM.java:26)
at org.eclipse.birt.report.engine.layout.html.HTMLAbstractLM.layout(HTMLAbstractLM.java:140)
at org.eclipse.birt.report.engine.layout.html.HTMLInlineStackingLM.resumeLayout(HTMLInlineStackingLM.java:111)
at org.eclipse.birt.report.engine.layout.html.HTMLInlineStackingLM.layoutNodes(HTMLInlineStackingLM.java:160)
at org.eclipse.birt.report.engine.layout.html.HTMLBlockStackingLM.layoutNodes(HTMLBlockStackingLM.java:71)
at org.eclipse.birt.report.engine.layout.html.HTMLRepeatHeaderLM.layoutChildren(HTMLRepeatHeaderLM.java:46)
at org.eclipse.birt.report.engine.layout.html.HTMLPageLM.layout(HTMLPageLM.java:92)
at org.eclipse.birt.report.engine.layout.html.HTMLReportLayoutEngine.layout(HTMLReportLayoutEngine.java:100)
at org.eclipse.birt.report.engine.api.impl.RunAndRenderTask.doRun(RunAndRenderTask.java:181)
I have tried checking by placing the jar "org.eclipse.datatools.enablement.oda.xml.jar" from BIRT 4.5 to BIRT 4.8 and it is working as expected.. but we should not.
Can someone please help me here why BIRT 4.8 report engine is not having the "org.eclipse.datatools.enablement.oda.xml.jar" or is there any other to overcome this error.
-Thanks in advance,
vinod
FUDForum. Page generated in 0.03815 seconds
