Re: Set interface class operations [message #1792415 is a reply to message #1792366] |
Tue, 17 July 2018 13:27 |
Hi Ron,
you can add operations either via a class diagram or the property view. In case of the diagram, select the "Operation" tool from the palette and create a new one in the operation compartment of an interface. Normally, you should well see "owned operations" in the UML tab of the property view once an interface is selected. You can then add a new operation using "+" button. If not, please state which Papyrus version you are using.
Please note (in particular when being used to C++) the difference between an "operation" (a specification) and a behavior aka "method" providing an implementation. Both are linked via the "specification" and "method" references, respectively. Interfaces typically contain operations, but not behaviors.
FUDForum. Page generated in 0.03905 seconds
