Titan 6.4.0 Docker images published in DockerHub [message #1792243] |
Fri, 13 July 2018 03:36  |
Dear all,
for those of you who wish to play with Titan in the form of a docker image,
we have published two such images in DockerHub:
https://hub.docker.com/u/eclipsetitan/
https://hub.docker.com/r/eclipsetitan/titan-alpine/
A minimal Docker image for Eclipse Titan 6.4.0 based on Alpine Linux.
pull with:
docker pull eclipsetitan/titan-alpine:6.4.0
https://hub.docker.com/r/eclipsetitan/titan-ubuntu/
A Docker image for Eclipse Titan 6.4.0 based on Ubuntu 18.04 LTS.
pull with:
docker pull eclipsetitan/titan-ubuntu:6.4.0
The Dockerfiles used to generate these images:
FROM alpine:edge
MAINTAINER Aron Simon <aron.simon@sigmatechnology.se>
## INSTALL DEPENDENCIES
RUN apk update && \
apk add --no-cache sudo make git g++ diffutils expect openssl-dev libxml2-dev libxml2-utils ncurses-dev flex bison perl libexecinfo-dev bash
## CREATE SUDOER USER
RUN adduser -S -D -G root -h /home/titan -s /bin/bash titan && \
echo "titan:titan" | chpasswd && \
echo "titan ALL=(ALL) NOPASSWD: ALL" >> /etc/sudoers
USER titan
## SETUP .BASHRC TO SETUP HOSTS FILE AT THE BOOT TIME
RUN echo 'sudo sh -c "cp /etc/hosts /etc/append && (echo \"127.0.1.1 $HOSTNAME\"; cat /etc/append) > /etc/hosts"' >> /home/titan/.bashrc
RUN echo 'sh' >> /home/titan/.bashrc
## SET UP ENV VARIABLES
ENV TTCN3_DIR=/home/titan/titan.core/Install
ENV PATH=$TTCN3_DIR/bin:$PATH \
LD_LIBRARY_PATH=$TTCN3_DIR/lib:$LD_LIBRARY_PATH
## CLONE TITAN
WORKDIR /home/titan
RUN git clone https://github.com/eclipse/titan.core.git
WORKDIR /home/titan/titan.core/
RUN git checkout tags/6.4.0
## SET FLAGS
RUN echo 'ALPINE_LINUX := yes \n\
TTCN3_DIR := /home/titan/titan.core/Install \n\
XMLDIR := /usr \n\
OPENSSL_DIR := /usr \n\
JNI := no \n\
GEN_PDF := no' >> Makefile.personal
## BUILD TITAN
RUN make install
ENTRYPOINT /bin/bash
and
FROM ubuntu:18.04
ENV DEBIAN_FRONTEND=noninteractive
RUN apt-get update && \
apt-get install -yq \
git gdb curl expect g++ make libssl-dev \
libxml2-dev libncurses5-dev flex bison \
xutils-dev ant xsltproc automake perl sudo
RUN useradd --create-home --shell /bin/bash titan && \
adduser --disabled-password titan sudo && \
USER titan
## SETUP .BASHRC TO SETUP HOSTS FILE AT THE BOOT TIME 150.132.184.69
## CLONE TITAN
## SET FLAGS
RUN echo 'TTCN3_DIR := /home/titan/titan.core/Install' >> Makefile.personal
RUN echo 'XMLDIR := /usr' >> Makefile.personal
RUN echo 'OPENSSL_DIR := /usr' >> Makefile.personal
RUN echo 'JNI := no' >> Makefile.personal
RUN echo 'GEN_PDF := no' >> Makefile.personal
## BUILD TITAN
RUN make install
For some other examples of Dockerfiles , please see :
Titan in Docker part 1
https://www.eclipse.org/forums/index.php/t/1091625/
Looking forward to your feedback
Best regards
Elemer
[Updated on: Fri, 13 July 2018 12:29] by Moderator
Re: Titan 6.4.0 Docker images published in DockerHub [message #1792537 is a reply to message #1792243] |
Thu, 19 July 2018 05:00   |
Dear all,
As time passes, we acquire more experience with the Titan images published and we update them regularly;
hence we recommend pulling them again from time to time, as we will indicate in this forum.
Although the interactive mode of the images works perfectly, there might be some glitches in the non-interactive one;
on Tuesday I tried to use the published Titan images in non-interactive mode, as below:
docker run eclipsetitan/titan-alpine ls
The created container executed without the expected logs. I tried to fix it as soon as possible as the non-interactive mode is the basis of the automated builds.
The reason of the problem is a conflict between the Docker CMD and our personalized bash initial mechanism, which we tried to fix the hosts file with:
We gave up this modification for now, so the non-interactive mode is working again.
Without this fix, the following feature is not working yet in TTCN3 (create component explicitly in "localhost"):
var MyComponentType myNewComponent := MyComponentType.create("My component name", "localhost")
The relevant test is here.
An example of how to run the Titan demo-project in Docker using non-interactive mode:
docker run eclipsetitan/titan-alpine sh -c 'cd TTCN3_DIR/demo && make && ttcn3_start MyExample MyExample.cfg'
The simplified Dockerfile for titan-alpine:
FROM alpine:edge
RUN apk update && \
apk add --no-cache \
sudo make git g++ diffutils expect openssl-dev \
libxml2-dev libxml2-utils ncurses-dev flex bison \
RUN adduser -S -D -G root -h /home/titan titan && \
USER titan
## CLONE TITAN
WORKDIR /home/titan
# Checkout release 6.4.0
## SET Makefile.personal
# ALPINE_LINUX := yes
# TTCN3_DIR := /home/titan/titan.core/Install
# XMLDIR := /usr
# OPENSSL_DIR := /usr
# JNI := no
# GEN_PDF := no
COPY Makefile.personal-alpine Makefile.personal
## BUILD TITAN
RUN make install
WORKDIR /home/titan
CMD compiler -v && /bin/sh
The simplified Dockerfile for titan-ubuntu:
FROM ubuntu:18.04
USER titan
## CLONE TITAN
# XMLDIR := /usr
# JNI := no
# GEN_PDF := no
COPY Makefile.personal-ubuntu Makefile.personal
## BUILD TITAN
RUN make install
WORKDIR /home/titan
CMD compiler -v && /bin/bash
Aron
FUDForum. Page generated in 0.05939 seconds
