Maven Projects always Build when Opening in Eclipse Photon [message #1792075] |
Tue, 10 July 2018 20:51 |
David Eisner Messages: 32 Registered: July 2009 |
Member |
I recently upgraded to to Eclipse Photon. Now Eclipse automatically builds the entire workspace every time I open a Maven project. This is true even though I have unchecked the Maven Project Builder in project Properties > Builders. This was not an issue when I was using previous versions of Eclipse (including Oxygen).
This is only happening with Maven projects. In fact, I checked out a fresh copy of my project, deleted the pom.xml file and .project files, and then created a fresh non-Maven Eclipse project from it, manually setting up the dependencies. It built fine, and if I closed and then re-opened the project, it did not auto-build (as expected). Note that I do have Project > Build Automatically checked, but that shouldn't matter.
Next, I converted this project to a Maven project (Configure > Convert to Maven Project), and now it exhibits the same undesired build-on-open behavior.
Does anybody have any suggestions? Is it a bug? Thanks.
FUDForum. Page generated in 0.03422 seconds
