Hiding Table Columns within script [message #1791999] |
Mon, 09 July 2018 14:50 |
Alexander Scott Messages: 6 Registered: July 2018 |
I am able to hide the column in HTML via assigning a style with "display:none;", but I have the issue that when exporting to Excel I get an ugly empty column.
Is there a way to assign a Hide Rule to a header/detail?
I have found this: https://wiki.eclipse.org/Add_Visibility_Rule_in_beforeFactory_(BIRT)
, but unable to get it working directly against a header/detail element.
My beforeFactory script so far:
importPackage( Packages.org.eclipse.birt.report.model.api );
importPackage(Packages.org.eclipse.birt.report.model.api.simpleapi);
reportContext.setPersistentGlobalVariable("COLUMN_SIZE", "20");
var COLUMN_SIZE = reportContext.getPersistentGlobalVariable("COLUMN_SIZE");
reportDesignHandle = reportContext.getReportRunnable().designHandle.getDesignHandle();
elementFactory = reportDesignHandle.getElementFactory();
dataSetHandle = elementFactory.newScriptDataSet( "Data Set" );
dataSetHandle.setDataSource( "Data Source" );
reportDesignHandle.getDataSets( ).add( dataSetHandle );
// public TableHandle newTableItem(String name, int columnNum, int headerRow, int detailRow, int footerRow) {
table = elementFactory.newTableItem( "table1", COLUMN_SIZE, 1, 1, 0 );
table.setWidth( "80%" );
table.setProperty( "dataSet", "Data Set" );
computedSet = table.getColumnBindings();
for ( var i = 0; i < COLUMN_SIZE; i++ ) {
cs1 = StructureFactory.createComputedColumn();
cs1.setName(i);
cs1.setExpression( "dataSetRow[" +i +"]" );
computedSet.addItem( cs1 );
// Header
myheader = table.getHeader( ).get( 0 );
headercell = myheader.getCells( ).get( i );
// tcell.setName("_header_id_" +i);
mylabel = elementFactory.newLabel( i );
mylabel.setText( "H" + i );
headercell.getContent( ).add( mylabel );
// detail
mydetail = table.getDetail( ).get( 0 );
detailcell = mydetail.getCells( ).get( i );
mydata = elementFactory.newDataItem( null );
mydata.setResultSetColumn(i);
detailcell.getContent( ).add( mydata );
if (i == 2) {
headercell.setStyleName("hidden");
hr = StructureFactory.createHideRule();
hr.setFormat("html");
hr.setExpression("false;");
ph = headercell.getContainer().getPropertyHandle("visibility");
ph.addItem(hr);
detailcell.setStyleName("hidden");
cs1.setAllowExport(false);
reportDesignHandle.getBody( ).add( table );
FUDForum. Page generated in 0.02948 seconds
