Re: Docker alpine Image - Forte & OPC UA - compiling errrors [message #1792381 is a reply to message #1792330] |
Mon, 16 July 2018 16:55 |
Franklin Amador Messages: 7 Registered: June 2018 |
I appreciate your input and will use the develop branch for compiling and testing.
I'll post all my work in github then try to create an Alpine forte image (35MB) with OPC UA (9MB), Modbus (4MB) and MQTT (?MB) already preconfigured. I won't be able to install OPC DA since this is a linux image. Also, I'm not sure I want to install FBDK (default protocol) as it will push the image to over 200MBs with Java JDK, but people are more than welcome to create their own images.
To summarize, my goal is for this image to be small enough to run in embedded devices already capable of running docker ce, but without the overhead of needing to compile forte.
Franklin
[Updated on: Mon, 16 July 2018 16:56] Report message to a moderator
Re: Docker alpine Image - Forte & OPC UA - compiling errrors [message #1799807 is a reply to message #1791465] |
Fri, 14 December 2018 00:47 |
I've come back to update the forte's Dockerfile but with the 1.10.0, develop and master branches I get the attached error compile logs regarding:
1) opcua_layer.cpp
2) opcua_handler.cpp
3) opcua_client_handler.cpp
I'm still using the version 3 of open62541.
The only noticeable changes are the 1) alpine openssl-dev package naming and 2) the move of the open62541.h file from /usr/local/include/open62541 to /usr/local/include.
Can you investigate and see what is wrong?
Note: the original Docker Image can still be pulled and deployed using the following command.
docker pull fdamador/forte:alpine
Thanks, F
[Updated on: Fri, 14 December 2018 00:49] Report message to a moderator
FUDForum. Page generated in 0.03574 seconds
