Home » Modeling » TMF (Xtext) » Parsing in reconciler failed. / [Model.feature] does not exist
Parsing in reconciler failed. / [Model.feature] does not exist [message #1791123] Sun, 24 June 2018 10:39 Go to next message
Alex Mising name is currently offline Alex Mising nameFriend
I started out with this grammar:
grammar org.xtext.example.mydsl.MyDsl with org.eclipse.xtext.common.Terminals
generate myDsl "http://www.xtext.org/example/mydsl/MyDsl"
Model: {Model}
    'greetings' '{'
    greetings+=Greeting*
Greeting:
    SimpleGreeting | GoodMorning | GoodEvening | CompoundGreeting;
CompoundGreeting:
    'greet' name=ID '{'
        lines+=CompoundGreetingMember*
CompoundGreetingMember:
    RefGreeting | InlineGreeting
InlineGreeting:
RefGreeting:
    'and' name=ID greet=[Greeting]
SimpleGreeting:
    'Hello' name=ID '!';
GoodMorning:
    'Good' 'morning' name=ID '!';
GoodEvening:
    'Good' 'evening' name=ID '!';
It was OK for parsing the following:
// day HappyDay
greetings {
	Hello X !
	Good morning Y !
	Good evening Z !
	greet script {
		Good morning A !
		Good evening B !
		and Thinking X
I then did the following change, adding the 'Day' rule used at the top of the model:
Model:
    Day
    'greetings' '{'
Day:
    'day' name=ID;
When launching Eclipse to test, I now:
  1. For the line 'and Thinking X' I have X underlined with red as a syntax error and the problems view reads "Couldn't resolve reference to greeting X"
  2. When commenting out the top line, I get the exception "Parsing in reconciler failed." (stack trace below)
  3. If I relaunch the Eclipse to test I get the exception "Model.greetings does not exist" (stack trace below) and the editor tab just has this message (no text area to actually edit the text
Now, (2) and (3) seem like there may be a problem in xtext itself. The stack trace does not involve any code I wrote. Does this seem like a bug I should report?
4719 [Worker-6] ERROR org.eclipse.xtext.ui.editor.reconciler.XtextDocumentReconcileStrategy  - Parsing in reconciler failed.
	at org.eclipse.xtext.resource.XtextResource.update(XtextResource.java:263)
	at org.eclipse.xtext.ui.editor.reconciler.XtextDocumentReconcileStrategy.doReconcile(XtextDocumentReconcileStrategy.java:182)
	at org.eclipse.xtext.ui.editor.reconciler.XtextDocumentReconcileStrategy.reconcile(XtextDocumentReconcileStrategy.java:90)
	at org.eclipse.xtext.ui.editor.reconciler.XtextReconciler.doRun(XtextReconciler.java:450)
	at org.eclipse.xtext.ui.editor.reconciler.XtextReconciler.access$3(XtextReconciler.java:430)
	at org.eclipse.xtext.ui.editor.reconciler.XtextReconciler$1.process(XtextReconciler.java:364)
	at org.eclipse.xtext.ui.editor.reconciler.XtextReconciler$1.process(XtextReconciler.java:1)
	at org.eclipse.xtext.util.concurrent.IUnitOfWork$Void.exec(IUnitOfWork.java:37)
	at org.eclipse.xtext.resource.OutdatedStateManager.exec(OutdatedStateManager.java:91)
	at org.eclipse.xtext.ui.editor.model.XtextDocument$XtextDocumentLocker.modify(XtextDocument.java:433)
	at org.eclipse.xtext.ui.editor.model.XtextDocument.internalModify(XtextDocument.java:166)
	at org.eclipse.xtext.ui.editor.reconciler.XtextReconciler.run(XtextReconciler.java:361)
	at org.eclipse.core.internal.jobs.Worker.run(Worker.java:56)
Caused by: java.lang.IllegalArgumentException: Model.greetings does not exist
	at org.eclipse.xtext.parser.DefaultEcoreElementFactory.add(DefaultEcoreElementFactory.java:108)
	at org.eclipse.xtext.parser.antlr.AbstractInternalAntlrParser.add(AbstractInternalAntlrParser.java:355)
	at org.eclipse.xtext.parser.antlr.AbstractInternalAntlrParser.add(AbstractInternalAntlrParser.java:362)
	at org.xtext.example.mydsl.parser.antlr.internal.InternalMyDslParser.ruleModel(InternalMyDslParser.java:194)
	at org.xtext.example.mydsl.parser.antlr.internal.InternalMyDslParser.entryRuleModel(InternalMyDslParser.java:99)
	at org.eclipse.xtext.parser.antlr.AbstractInternalAntlrParser.parse(AbstractInternalAntlrParser.java:561)
	... 20 more
Re: Parsing in reconciler failed. / [Model.feature] does not exist [message #1791124 is a reply to message #1791123] Sun, 24 June 2018 10:49 Go to previous messageGo to next message
Christian Dietrich is currently offline Christian DietrichFriend
can you please open a bug at github.com/eclipse/xtext-core for that.
the problem is that you are lazy with assigning things
Model:
day=Day
'greetings' '{'
and problem solved.
Twitter : @chrdietrich
Re: Parsing in reconciler failed. / [Model.feature] does not exist [message #1791125 is a reply to message #1791124] Sun, 24 June 2018 10:57 Go to previous message
Thank you!
Opened https://github.com/eclipse/xtext-core/issues/773
Previous Topic:Formatting multiple parser rules within curly brackets
Next Topic:Create files only once
Current Time: Fri Apr 26 07:32:13 GMT 2024
Powered by FUDForum. Page generated in 0.03365 seconds
