Home » Archived » BIRT » Multiselect parameter with dynamic sql(multi parameters)
Multiselect parameter with dynamic sql [message #1790552] Tue, 12 June 2018 14:56 Go to next message
I have a report that pulls training taken. I need the user to be able to select which filter to use to run the report; ( ie - by shop, department, date course taken). The selected parameter then sets the query to be run through a script. This part of the report is working fine.
However along with this, I would like the user to be able to select more than one training course. I am using the Open Access Birt Report tool.
I have tried several things I have found without success. Can anyone help?
I have Eclipse Neon version 4.6.0 loaded. I am working against a MySQL database.
Thanks in advance
Re: Multiselect parameter with dynamic sql [message #1790870 is a reply to message #1790552] Tue, 19 June 2018 07:17 Go to previous messageGo to next message
Use a Dynamic Filter Parameter. It gives the ability to select multiple values and several other options. Use the IN operator to achieve this.
  • Attachment: Capture.PNG
    (Size: 31.24KB, Downloaded 199 times)
Re: Multiselect parameter with dynamic sql [message #1790876 is a reply to message #1790870] Tue, 19 June 2018 09:10 Go to previous messageGo to next message
The Open Source BIRT does not have that built in scripting function. My screen does not look like yours.
Re: Multiselect parameter with dynamic sql [message #1791021 is a reply to message #1790552] Thu, 21 June 2018 10:39 Go to previous message
Help still needed
Previous Topic:Which task is fater (best performer)? (RunAndRender vs. Run and Render)
Next Topic:Maximo PDF Charts not rendering in SVG format
Current Time: Tue Apr 22 16:39:43 EDT 2025
Powered by FUDForum. Page generated in 0.04518 seconds
