Data visualisation of Kapua devices [message #1790510] |
Tue, 12 June 2018 07:54 |
Boitumelo Mahlobo Messages: 1 Registered: June 2018 |
I have created a Javascript and HTML dashboard, and what I want to do is to display data from Kapua on the dashboard. The way I deploy Kapua is by running the 5 Docker containers - SQL, Elasticsearch, Broker, Console and API.
The approaches that I have tried so far:
1. I was using the Kapua REST API to get data but kept on getting a 401 error although I was using an Authentication method in Java.
2. I was dockerising the dashboard and using the "-- link" command to connect Kapua-sql container to the dockerised container. I created a H2 server database at the address: localhost:8181. I then used the login details to connect from the dockerised dashboard to the created H2 server database.
Both of these two approaches have not worked. I was asking if there are any more approaches I could try, or maybe I could try implementing these two approaches differently.
FUDForum. Page generated in 0.01614 seconds
