Home » Modeling » TMF (Xtext) » How do I re-import a maven Xtext project?(I ran "mvn clean", how do I import project into new Eclipse workspace?)
How do I re-import a maven Xtext project? [message #1787086] Fri, 18 May 2018 12:00 Go to next message
Very basic question: how do I re-import an Xtext project for which I have deleted the ".project" files? I ran "mvn clean" and removed eclipse-specific stuff (.project/.classpath/.settings) in order to get to a state suitable for a "clean" import to a source repository. Before doing that I deleted the project from my workspace.
I had noticed the initial ".project" files had the maven nature, so I assumed I would be able to re-import using "Existing Maven Projects" facility, but that fails: the main language project's "GenerateMyDsl.mwe2" has a lot of erros about "Couldn't resolve reference to JvmIdentifiableElement 'baseName'." and such.
Is it possible to fix the project (I tried adding the plugin nature which I think was missing, but it did not seem to help)...
Re: How do I re-import a maven Xtext project? [message #1787087 is a reply to message #1787086] Fri, 18 May 2018 12:07 Go to previous messageGo to next message
is your project a maven project or a maven tycho project?
in doubt you can use the wizard to create all kinds of combinations
Re: How do I re-import a maven Xtext project? [message #1787088 is a reply to message #1787087] Fri, 18 May 2018 12:12 Go to previous messageGo to next message
It's maven tycho (as generated by Xtext) because I chose to have Eclipse plugin support.
I am comparing files manually now to figure out what's wrong. The first difference is that the main language module (the one with GenerateMyDsl.mwe2 ) had the Xtext nature in it after I re-imported, but originally that nature was NOT present. So I unconfigured Xtext and the problems view is clean, but now I can't run the launch configuration for "Generate MyDsl (mydsl) Language Infrastructure". It seems like it's missing the JRE and classpath, which I guess is because there is no Java nature on the project?
It seems to me I'm doing something very wrong, there should be some easy way to reimport from a clean state?
Re: How do I re-import a maven Xtext project? [message #1787091 is a reply to message #1787088] Fri, 18 May 2018 12:47 Go to previous messageGo to next message
Ok, so here's how I managed to "fix" it:
1) Re-import with File -> Import -> Existing Maven projects
This reads pom.xml and creates all projects, but your main language project will have errors in the "Generate[something].mwe2" file. This is because the pom.xml has "<packaging>eclipse-plugin</packaging>" which seems to confuse m2e, so the project doesn't even have the Java nature (no builder, etc). See below for next steps.
2) Open the pom.xml from Eclipse and edit to change packaging to "jar" and save. Then right-click on project and choose "Maven -> Update project..." and ok. This re-adds the Java nature to the project. UNDO your edit to return to eclipse-plugin packaging and REPEAT the "update project" again.
3) Right-click on project and go to "Java build path -> Source" and remove src/main/java and src/test/java so that it is empty (they were added by m2e when you switched to jar packaging above).
4) Right-click on project and go to "Configure -> Convert to Plugin Projects" and click Finish. You now have the plugin project nature again (it was also missing).
5) Right-click on project and go to "Plugin tools -> Update classpath..." . This restores the source folder (src, src-gen, xtend-gen) and adds the "Plug-in dependencies" to the classpath.
At this point you can run "Generate[something].mwe2" again.
So, I guess the root cause is that m2e does not really understand "eclipse-packaging"... Or is there some other "proper" way to do this?
Re: How do I re-import a maven Xtext project? [message #1787093 is a reply to message #1787091] Fri, 18 May 2018 12:52 Go to previous messageGo to next message
Do you have the m2e extensions for eclipse tycho installed
Re: How do I re-import a maven Xtext project? [message #1787094 is a reply to message #1787093] Fri, 18 May 2018 12:56 Go to previous messageGo to next message
I am pretty sure I don't. How does one install these?
Re: How do I re-import a maven Xtext project? [message #1787096 is a reply to message #1787094] Fri, 18 May 2018 13:00 Go to previous messageGo to next message
https://wiki.eclipse.org/Tycho/FAQ#What_do_I_need_to_install_in_my_Eclipse_IDE_to_easily_work_with_Tycho.3F
Re: How do I re-import a maven Xtext project? [message #1787097 is a reply to message #1787096] Fri, 18 May 2018 13:05 Go to previous message
You'll never guess what happened next Christian... everything "just works"! :-)
Thanks a lot for your help.
Previous Topic:Xtext 2.9.1 and Eclipse Photon Milestone 6 (4.8.0M6)
Next Topic:Validating x,y coordinates
Current Time: Thu Jul 10 19:56:09 EDT 2025
Powered by FUDForum. Page generated in 0.26332 seconds
