Home » Archived » BIRT » Birt report is freezing when i try edit dataset
Birt report is freezing when i try edit dataset [message #1786778] Fri, 11 May 2018 04:14 Go to next message
Hello, i am facing a problem with birt reports, i have a report that freeze wherever i try to edit the dataset i have (add new field to the query or to refresh the dataset) any help please?
Re: Birt report is freezing when i try edit dataset [message #1790898 is a reply to message #1786778] Tue, 19 June 2018 16:33 Go to previous message
Are you sure the connection to the datasource is OK ? Cause BIRT is quite freezy when the datasource you're trying to connect to doesn't answer or doesn't answer "fast" ?
Previous Topic:Joint Data Set passing on parameter
Next Topic:BIRT Runtime 4.7.0 Release Build download Availability
Current Time: Wed Oct 29 07:20:57 EDT 2025
Powered by FUDForum. Page generated in 0.03102 seconds
