Home » Archived » BIRT » Group Header Repeating Before Page Break
Group Header Repeating Before Page Break [message #1786711] Wed, 09 May 2018 13:43 Go to next message
I'm having a problem with retaining the title of groups before the page break when the data does not fit on the same page.
Titles repeat normally on the next page but should not be displayed on the previous page because the data will not appear in it.
I already researched the forum and found no similar problem and need to solve this problem.
I'm using Birt 2.2.1 and the report has a table with three groups, each with a header and footer.
[Updated on: Thu, 10 May 2018 09:51] by Moderator
Re: Group Header Repeating Before Page Break [message #1790899 is a reply to message #1786711] Tue, 19 June 2018 16:35 Go to previous messageGo to next message
First, why are you using 2.2.1 version of BIRT ? You should try the latest version I guess.
Then, can you try to reproduce the problem with the default BIRT datasource ? ( classicmodel)
Re: Group Header Repeating Before Page Break [message #1791040 is a reply to message #1790899] Thu, 21 June 2018 16:05 Go to previous message
Thanks for the reply.
After researching I realized that there is no practical solution to this problem in version 2.1.
It was decided that the layout of the report would be changed.
Previous Topic:Maximo PDF Charts not rendering in SVG format
Next Topic:Just added tables,, but cannot find them in BIRT
Current Time: Tue Apr 29 17:14:39 EDT 2025
Powered by FUDForum. Page generated in 0.03559 seconds
