Home » Modeling » TMF (Xtext) » XBASE content assist inconsistent behavior(XBASE content assist inconsistent behavior)
Re: XBASE content assist inconsistent behavior [message #1786435 is a reply to message #1786428] |
Thu, 03 May 2018 09:22 |
MyDslProposalProvider now inherits from XbaseProposalProvider and not TerminalsProposalProvider which behaves diffently.
e.g. if you move stuff like org.eclipse.xtext.common.ui.contentassist.TerminalsProposalProvider.complete_ID(EObject, RuleCall, ContentAssistContext, ICompletionProposalAcceptor)
back to your proposal provider it will work again.
alternatively simply customize the completeX_y methods e.g. completeGreeting_Name
Twitter : @chrdietrich
Re: XBASE content assist inconsistent behavior [message #1786479 is a reply to message #1786435] |
Fri, 04 May 2018 05:57 |
Thomas Petrou Messages: 12 Registered: April 2018 |
Thanks Christian, some more clarification if you don't mind
i have copied and pasted (modified java to be xtend) the whole implementation from the terminals abstract provider in my MyDslProposalProvider (since i didn't have anything myself) here it is
[code]
* generated by Xtext 2.12.0
package org.xtext.example.mydsl.ui.contentassist
import org.eclipse.emf.ecore.EObject
import org.eclipse.jface.text.contentassist.ICompletionProposal
import org.eclipse.xtext.Assignment
import org.eclipse.xtext.GrammarUtil
import org.eclipse.xtext.RuleCall
import org.eclipse.xtext.ui.editor.contentassist.ConfigurableCompletionProposal
import org.eclipse.xtext.ui.editor.contentassist.ContentAssistContext
import org.eclipse.xtext.ui.editor.contentassist.ICompletionProposalAcceptor
import org.eclipse.xtext.ui.editor.contentassist.PrefixMatcher
import org.eclipse.xtext.util.Strings
public class MyDslProposalProvider extends AbstractMyDslProposalProvider {
override public void complete_ID(EObject model, RuleCall ruleCall, ContentAssistContext context,
ICompletionProposalAcceptor acceptor) {
if (doCreateIdProposals()) {
var PrefixMatcher newMatcher = new PrefixMatcher() {
override public boolean isCandidateMatchingPrefix(String name, String prefix) {
var String strippedName = name;
if (name.startsWith("^") && !prefix.startsWith("^")) {
strippedName = name.substring(1);
return context.getMatcher().isCandidateMatchingPrefix(strippedName, prefix);
var ContentAssistContext myContext = context.copy().setMatcher(newMatcher).toContext();
var String feature = getAssignedFeature(ruleCall);
var String proposalText = if (feature !== null)
feature
else
Strings.toFirstUpper(ruleCall.getRule().getName().toLowerCase());
var String displayText = proposalText;
displayText = proposalText + " - " + ruleCall.getRule().getName();
proposalText = getValueConverter().toString(proposalText, ruleCall.getRule().getName());
var ICompletionProposal proposal = createCompletionProposal(proposalText, displayText, null, myContext);
if (proposal instanceof ConfigurableCompletionProposal) {
var ConfigurableCompletionProposal configurable = proposal as ConfigurableCompletionProposal;
configurable.setSelectionStart(configurable.getReplacementOffset());
configurable.setSelectionLength(proposalText.length());
configurable.setAutoInsertable(false);
configurable.setSimpleLinkedMode(myContext.getViewer(), '\t', ' ');
acceptor.accept(proposal);
def private String getAssignedFeature(RuleCall call) {
var Assignment ass = GrammarUtil.containingAssignment(call);
if (ass !== null) {
var String result = ass.getFeature();
if (result.equals(result.toLowerCase()))
result = Strings.toFirstUpper(result);
return result;
return null;
override public void complete_STRING(EObject model, RuleCall ruleCall, ContentAssistContext context,
if (doCreateStringProposals()) {
createStringProposal(context, acceptor, feature, ruleCall);
def private void createStringProposal(ContentAssistContext context, ICompletionProposalAcceptor acceptor,
String feature, RuleCall ruleCall) {
feature
else
displayText = displayText + " - " + ruleCall.getRule().getName();
var ICompletionProposal proposal = createCompletionProposal(proposalText, displayText, null, context);
configurable.setSelectionStart(configurable.getReplacementOffset() + 1);
configurable.setSelectionLength(proposalText.length() - 2);
configurable.setSimpleLinkedMode(context.getViewer(), proposalText.charAt(0), '\t');
override public void complete_INT(EObject model, RuleCall ruleCall, ContentAssistContext context,
if (doCreateIntProposals()) {
// createIntProposal(context, acceptor, feature, "0");
createIntProposal(context, acceptor, ruleCall, feature, 1);
// createIntProposal(context, acceptor, feature, "2");
// createIntProposal(context, acceptor, feature, "5");
// createIntProposal(context, acceptor, feature, "10");
// createIntProposal(context, acceptor, feature, "50");
// createIntProposal(context, acceptor, feature, "100");
// createIntProposal(context, acceptor, feature, "1000");
def protected boolean doCreateIntProposals() {
return true;
def protected boolean doCreateStringProposals() {
return true;
def protected boolean doCreateIdProposals() {
return true;
def private void createIntProposal(ContentAssistContext context, ICompletionProposalAcceptor acceptor,
RuleCall ruleCall, String feature, int i) {
var String proposalText = getValueConverter().toString(i, ruleCall.getRule().getName());
var String displayText = proposalText + " - " + ruleCall.getRule().getName();
if (feature != null)
displayText = proposalText + " - " + feature;
configurable.setSimpleLinkedMode(context.getViewer(), '\t', ' ');
override public void complete_ML_COMMENT
(EObject model
, RuleCall ruleCall, ContentAssistContext context, ICompletionProposalAcceptor acceptor) {
// subclasses may override
override public void complete_SL_COMMENT(EObject model, RuleCall ruleCall, ContentAssistContext context, ICompletionProposalAcceptor acceptor) {
override public void complete_WS(EObject model, RuleCall ruleCall, ContentAssistContext context, ICompletionProposalAcceptor acceptor) {
override public void complete_ANY_OTHER(EObject model, RuleCall ruleCall, ContentAssistContext context, ICompletionProposalAcceptor acceptor) {
[code]
Name proposal now works. Unfortunately the proposal for the "!" does not work. I understand that i will need to create a new method for that. If yes which which is the method?
After checking the above i have also modified the grammar a little bit (an XBlockExpression has been added). It now looks
grammar org.xtext.example.mydsl.MyDsl with org.eclipse.xtext.xbase.Xbase
import "http://www.eclipse.org/xtext/xbase/Xbase"
generate myDsl "http://www.xtext.org/example/mydsl/MyDsl"
Model:
greetings+=Greeting*;
Greeting:
'Hello' name=ID expr = XBlockExpression '!';
ID (=name) proposal works but the proposal of the opening curly brackets of the XBlockExpression proposal does not work, same for the ending '!'
Does this mean that i need to implement the methods for the openning and closing curly brackets? What kind of behaviour should i expect within XBase expresions?
Kind regards and thank you again
Thomas
Current Time: Thu Sep 19 10:04:09 GMT 2024
Powered by FUDForum. Page generated in 0.04590 seconds
