| EclipseLink + Apache Derby [message #1786255] |
Fri, 27 April 2018 15:46  |
Hi, I'n newbie in ORM discussions....but I have a problem with one properties defined in my model class: Categoria...here it is:
@Entity
@Table(name = "APP.CATEGORIAS")
@NamedQueries({ @NamedQuery(name = "Categorias.buscarTodas", query = "select c from APP.CATEGORIAS c")
public class Categoria {
@Id
@SequenceGenerator(name = "SEQ_CAT", initialValue = 1, allocationSize = 53)
@GeneratedValue(strategy = GenerationType.SEQUENCE, generator = "SEQ_CAT")
@Column(name = "IDCATEGORIA", nullable = false)
private final IntegerProperty idcategoria;
@Column(name = "CODIGO", length = 10, nullable = false)
private StringProperty codigo;
@Column(name = "DESCRIPCION", length = 150, nullable = true)
private StringProperty descripcion;
The column is "descripcion" ...this is the table in Derby:
CREATE TABLE APP.CATEGORIAS (
IDCATEGORIA INTEGER DEFAULT AUTOINCREMENT: start 1 increment 1 NOT NULL,
CODIGO VARCHAR(10) NOT NULL,
DESCRIPCION VARCHAR(150),
CONSTRAINT CATEGORIAS_PK PRIMARY KEY (IDCATEGORIA)
This is my persistence.xml:
<persistence-unit name="balthusPU" transaction-type="RESOURCE_LOCAL">
<provider>org.eclipse.persistence.jpa.PersistenceProvider</provider>
<class>ar.dignitas.balthus.model.Categoria</class>
<properties>
<property name="javax.persistence.jdbc.driver" value="org.apache.derby.jdbc.ClientDriver40" />
<property name="javax.persistence.jdbc.url" value="jdbc:derby://localhost:1527/C:\Sistemas\data\balthus;create=false" />
<property name="javax.persistence.jdbc.user" value="app" />
<property name="javax.persistence.jdbc.password" value="app" />
<property name="eclipselink.logging.level" value="ALL"/>
<!-- <property name="eclipselink.ddl-generation" value="drop-and-create-tables" /> -->
<!-- <property name="eclipselink.ddl-generation.output-mode" value="database" /> -->
</properties>
</persistence-unit>
</persistence>
When I try to run my SE application the next erro appear:
The type [class javafx.beans.property.StringProperty] for the attribute [descripcion] on the entity class [class ar.dignitas.balthus.model.Categoria] is not a valid type for a serialized mapping. The attribute type must implement the Serializable interface.
I don't know why ...any helps?
TIA
FUDForum. Page generated in 0.06786 seconds
