| Eclipse crashed and now my workplace won't open. What should I do? [message #1786253] |
Fri, 27 April 2018 13:40  |
My Eclipse crashed and when I went to open it again it crashes when loading the workplace. I'm assuming the workplace didn't save correctly. Is there any easy fix? Should I make a new workplace? And what's the best way to do that?
This is Release 4.7.0 (Oxygen).
Here's the error message:
!ENTRY org.eclipse.osgi 4 0 2018-04-27 13:30:09.758
!MESSAGE Application error
!STACK 1
java.lang.NoClassDefFoundError: org/eclipse/core/resources/IContainer
at org.eclipse.ui.internal.ide.application.IDEApplication.start(IDEApplication.java:152)
at org.eclipse.equinox.launcher.Main.invokeFramework(Main.java:653)
at org.eclipse.equinox.launcher.Main.basicRun(Main.java:590)
at org.eclipse.equinox.launcher.Main.run(Main.java:1499)
Caused by: java.lang.ClassNotFoundException: An error occurred while automatically activating bundle org.eclipse.core.resources (94).
at org.eclipse.osgi.internal.hooks.EclipseLazyStarter.postFindLocalClass(EclipseLazyStarter.java:112)
at org.eclipse.osgi.internal.loader.classpath.ClasspathManager.findLocalClass(ClasspathManager.java:529)
at org.eclipse.osgi.internal.loader.ModuleClassLoader.findLocalClass(ModuleClassLoader.java:328)
at org.eclipse.osgi.internal.loader.BundleLoader.findLocalClass(BundleLoader.java:368)
at org.eclipse.osgi.internal.loader.sources.SingleSourcePackage.loadClass(SingleSourcePackage.java:36)
at org.eclipse.osgi.internal.loader.BundleLoader.findClassInternal(BundleLoader.java:442)
at org.eclipse.osgi.internal.loader.BundleLoader.findClass(BundleLoader.java:395)
at org.eclipse.osgi.internal.loader.BundleLoader.findClass(BundleLoader.java:387)
at org.eclipse.osgi.internal.loader.ModuleClassLoader.loadClass(ModuleClassLoader.java:150)
... 13 more
Caused by: org.osgi.framework.BundleException: Exception in org.eclipse.core.resources.ResourcesPlugin.start() of bundle org.eclipse.core.resources.
at org.eclipse.osgi.internal.framework.BundleContextImpl.startActivator(BundleContextImpl.java:800)
at org.eclipse.osgi.internal.framework.BundleContextImpl.start(BundleContextImpl.java:729)
at org.eclipse.osgi.internal.framework.EquinoxBundle.startWorker0(EquinoxBundle.java:933)
at org.eclipse.osgi.internal.framework.EquinoxBundle$EquinoxModule.startWorker(EquinoxBundle.java:309)
at org.eclipse.osgi.container.Module.doStart(Module.java:581)
at org.eclipse.osgi.container.Module.start(Module.java:449)
at org.eclipse.osgi.framework.util.SecureAction.start(SecureAction.java:468)
at org.eclipse.osgi.internal.hooks.EclipseLazyStarter.postFindLocalClass(EclipseLazyStarter.java:103)
... 22 more
Caused by: org.eclipse.core.internal.resources.ResourceException: Incompatible file format. Workspace was saved with an incompatible version: 0.
at org.eclipse.core.internal.resources.WorkspaceTreeReader.getReader(WorkspaceTreeReader.java:59)
at org.eclipse.core.internal.resources.WorkspaceTreeReader.getReader(WorkspaceTreeReader.java:67)
at org.eclipse.core.internal.resources.SaveManager.restoreTree(SaveManager.java:1056)
at org.eclipse.core.internal.resources.SaveManager.restore(SaveManager.java:719)
at org.eclipse.core.internal.resources.SaveManager.startup(SaveManager.java:1587)
at org.eclipse.core.internal.resources.Workspace.startup(Workspace.java:2399)
at org.eclipse.core.internal.resources.Workspace.open(Workspace.java:2156)
at org.eclipse.core.resources.ResourcesPlugin.start(ResourcesPlugin.java:467)
at org.eclipse.osgi.internal.framework.BundleContextImpl$3.run(BundleContextImpl.java:779)
at org.eclipse.osgi.internal.framework.BundleContextImpl$3.run(BundleContextImpl.java:1)
at org.eclipse.osgi.internal.framework.BundleContextImpl.startActivator(BundleContextImpl.java:772)
... 29 more
[Updated on: Fri, 27 April 2018 14:07] by Moderator
FUDForum. Page generated in 0.07532 seconds
