Home » Modeling » TMF (Xtext) » DefaultResourceDescriptionManager.isAffected inconsistency when AutoBuild is cancelled
DefaultResourceDescriptionManager.isAffected inconsistency when AutoBuild is cancelled [message #1785963] Mon, 23 April 2018 11:09 Go to next message
I've been having inconsistencies in the output that generates my grammar and i've finally been able to reproduce it in a small project and find the root cause.
Let's suppose this dummy grammar
grammar org.xtext.example.mydsl.AutoBuildCancel with org.eclipse.xtext.common.Terminals
generate autoBuildCancel "http://www.xtext.org/example/mydsl/AutoBuildCancel"
Model: Entity | Statement;
Entity: 'ENTITY' name=ID atributes+=Atribute+;
Atribute: 'ATRIBUTE' name=ID;
Statement: 'STATEMENT' name=ID entity=[Entity];
And this generator
class AutoBuildCancelGenerator extends AbstractGenerator {
	@Inject extension IQualifiedNameProvider
	override void doGenerate(Resource resource, IFileSystemAccess2 fsa, IGeneratorContext context) {
		val model = resource.contents.get(0) as Model
		fsa.generateFile(model.fullyQualifiedName.toString("/") + ".txt", model.toTest)
	def dispatch CharSequence toTest(Entity entity) '''
		ENTITY «entity.name»
			«FOR attr : entity.atributes»
				«attr.name»
			«ENDFOR»
	def dispatch CharSequence toTest(Statement entity) '''
		STATEMENT TO «entity.entity.toTest»
A resource can contain a single Entity with some attributes or a single statement referencing an entity
The result of the compilation is the list of attributes in both cases.
E1 source
ENTITY E1
	ATRIBUTE A1
	ATRIBUTE A2
E1 generated
ENTITY E1
	A1
	A2
S1 source
STATEMENT S1 E1
S1 generated
STATEMENT TO ENTITY E1
	A1
	A2
Xtext handles changes pretty well because it knows that S1 references E1 and if i add a new attribute, E1 IResourceDescription changes and DefaultResourceDescriptionManager.isAffected can detect all resources that are affected.
The problem comes when the AutoBuild job is cancelled in the generation phase and changes to the IResourceDescription's are "commited".
In this case, the build starts again but it doesn't detect a change, so S1 is not generated.
To reproduce it:
* Close all open windows in the Eclipse editor used to test the language
* Open only E1, add a new attribute and save
* Both E1.txt and S1.txt have the new attribute
* Add a breakpoint in doGenerate
* Leave open again only E1, add another attribute and save
* While stopped in doGenerate, open S1. This causes the build to interrupt (discussion in here https://www.eclipse.org/forums/index.php/m/1773425/?srch=autobuild#msg_1773425)
* Continue doGenerate and XtextBuilder.handleCancelled is called
* Build starts again automatically but it doesn't detect the new attribute
* E1.txt has the new attribute but S1.txt does not
Should i open a ticket on github?
Last versions of Xtext (with lots of custom code) it's pretty fast, but the project i'm using is almost 12.000 files and 200Mb, so when this problem occurs and i have to do a full build, which takes more than 10 minutes (and then it has to do other things that take up 10 or 15 more minutes)
I've detected myself cancelations of the build because of:
* Eclipse JPA plugins https://www.eclipse.org/forums/index.php/t/1087065/ I've uninstalled them because i don't need them
* Subclipse used in the project: if i have the project in svn, it almost always cancels builds. I'm testing without it for now https://git.eclipse.org/r/#/c/101379/
* Opening a file https://www.eclipse.org/forums/index.php/m/1773425/?srch=autobuild#msg_1773425
Because of the combination of problems, i'm thinking that maybe i could customize Xtext to not honor build cancelation, but maybe is not posible ...
Any pointers to "live" with this problems would be greatly appreciated
Sergio
Re: DefaultResourceDescriptionManager.isAffected inconsistency when AutoBuild is cancelled [message #1785968 is a reply to message #1785963] Mon, 23 April 2018 11:47 Go to previous messageGo to next message
- do you have a product or not?
- if yes you could have a custom progress monitor in a custom xtextBuilder / clusteringbuilderstate that lies about cancellation, but i am not sure if this will work and which bad side effects it has.
Re: DefaultResourceDescriptionManager.isAffected inconsistency when AutoBuild is cancelled [message #1785969 is a reply to message #1785968] Mon, 23 April 2018 11:52 Go to previous messageGo to next message
p.s.: do you have polling enabled in your workspace settings?
Re: DefaultResourceDescriptionManager.isAffected inconsistency when AutoBuild is cancelled [message #1785986 is a reply to message #1785969] Mon, 23 April 2018 16:22 Go to previous messageGo to next message
No, i've tested it with default workspace on latest Eclipse Oxygen 3a and XText 2.13. It happened also in Neon
About having a product, yes it is. The Eclipse editor part is not ready for the users, we still use an old technology, but the compiler is used in an internal project via CI with Jenkins and "runtime compilations" and it works fine.
I'll take a look on how to avoid cancelation and pro's/con's
If i'ts ok i'll file a bug on github xtext-core. I'll try to investigate more, but i don't know if i have the necessary knowledge to deep diver or provide a good general solution instead of a "dirty hack"
Re: DefaultResourceDescriptionManager.isAffected inconsistency when AutoBuild is cancelled [message #1785988 is a reply to message #1785986] Mon, 23 April 2018 16:55 Go to previous messageGo to next message
Main problem. Finding the cause in your setup.
For the on open you can create an issue at eclipse/Xtext-eclipse in github
Re: DefaultResourceDescriptionManager.isAffected inconsistency when AutoBuild is cancelled [message #1786009 is a reply to message #1785988] Tue, 24 April 2018 02:39 Go to previous messageGo to next message
https://github.com/eclipse/xtext-eclipse/issues/648
What do you mean "finding the cause in your setup"?
If it's about the root cause of build cancelations, i've found the main three that affects me as i said, and it seems that they're affecting others as well:
Sergio
Re: DefaultResourceDescriptionManager.isAffected inconsistency when AutoBuild is cancelled [message #1786198 is a reply to message #1786009] Thu, 26 April 2018 13:17 Go to previous message
XtextBuilder has this function
private boolean shouldCancelBuild(int buildKind) {
		return buildKind == IncrementalProjectBuilder.AUTO_BUILD && isInterrupted();
So it only cancels when the autobuild job has been interrupted with a job with more priority
Eclipse doc says "This method allows long running builders to respond to this interruption in a timely manner. Builders are not required to respond to interruption requests"
Because isInterupted is final and shouldCanceBuild is private, i have to override 3 methods
@Singleton
public class CustomXtextBuilder extends XtextBuilder {
	private static final ThreadLocal<IProgressMonitor> threadLocalMonitor = new ThreadLocal<>();
	protected IProject[] build(int kind, Map args, IProgressMonitor monitor) throws CoreException {
		try {
			threadLocalMonitor.set(monitor);
			return super.build(kind, args, monitor);
		} finally {
			threadLocalMonitor.remove();
	protected void incrementalBuild(IResourceDelta delta, IProgressMonitor monitorOld) throws CoreException {
		IProgressMonitor monitor = threadLocalMonitor.get();
		SubMonitor progress = SubMonitor.convert(monitor, 1);
		try {
			super.incrementalBuild(delta, progress.newChild(1));
		} finally {
			if (monitor != null)
				monitor.done();
	protected void fullBuild(IProgressMonitor monitorOld, boolean isRecoveryBuild) throws CoreException {
		try {
			super.fullBuild(monitor, isRecoveryBuild);
		} finally {
				monitor.done();
class CustomOverridingModule extends AbstractGenericModule {
	def override configure(Binder binder) {
		super.configure(binder)
		binder.bind(XtextBuilder).to(CustomXtextBuilder);
<plugin>
	<extension
        point="org.eclipse.xtext.ui.shared.overridingGuiceModule">
     <module
           class="org.xtext.example.mydsl.ui.CustomOverridingModule">
     </module>
With this change, the problems seems to be solved.
The build is not interrupted with high priority jobs, but it still can be cancelled by the user
Sergio
Previous Topic:Announcing Xtext&Xtend 2.14 RC1
Next Topic:Problem with Linking to library models
Current Time: Fri Jul 18 13:59:51 EDT 2025
Powered by FUDForum. Page generated in 0.07133 seconds
