Re: I can´t create Relationship edge [message #1786160 is a reply to message #1786090] |
Thu, 26 April 2018 09:26 |
Hi Cristian,
In your metamodel, the relation is based on an element of type "Connection" (a Message or an Association). I guess "Secuence" inherit from Connection ?
From what I see on your screenshots, your edge creation tool does not create any instance of type "Connection". As your edge is an "Element based edge", it is the responsibility of the edge creation tool to create a new Instance of this element. And next you set the "origin" and "target" values of the new "Connection" intance.
Florian
Re: I can´t create Relationship edge [message #1786172 is a reply to message #1786162] |
Thu, 26 April 2018 12:41 |
The problem is the context. You change the context with "var:source". The reference "object" Is on the type "Lane". You have to retrieve to right context. If the context is the parent of the source figure, you will have aql:source.eContainer().
FUDForum. Page generated in 0.03820 seconds
