Azure IoT hub Certificate Authority Connection [message #1785771] |
Thu, 19 April 2018 13:27 |
Salvatore Di Liberto Messages: 6 Registered: April 2018 |
I want to connect Kura to Azure iot hub with the ssl certificates, in particular the X.509 certificate, so without the SAS token.
So, I followed the Microsoft guide to create the X.509 CA certificates (https://docs.microsoft.com/en-us/azure/iot-hub/iot-hub-security-x509-get-started).
I added the created certificates in the SSL configuration and Server SSL certificate of Kura. I setted the cloud service with this guide: https://eclipse.github.io/kura/cloud/kura-azure.html.
But, the connection fails. I have this error in the kura.log:
o.e.k.c.d.t.m.MqttDataTransport - xxxxx Connect failed. Forcing disconnect. xxxxx {}
Not authorized to connect (5)
at org.eclipse.paho.client.mqttv3.internal.ExceptionHelper.createMqttException(ExceptionHelper.java:28)
at org.eclipse.paho.client.mqttv3.internal.ClientState.notifyReceivedAck(ClientState.java:990)
at org.eclipse.paho.client.mqttv3.internal.CommsReceiver.run(CommsReceiver.java:118)
at java.lang.Thread.run(Thread.java:745)
2018-04-19 12:14:41,719 [qtp8650332-33] INFO o.e.k.c.d.t.m.MqttDataTransport - Closing client...
2018-04-19 12:14:41,720 [qtp8650332-33] INFO o.e.k.c.d.t.m.MqttDataTransport - Closed
2018-04-19 12:14:41,722 [pool-11-thread-1] INFO o.e.k.c.s.r.LogStatusRunnable - Notification LED off
2018-04-19 12:14:41,724 [pool-11-thread-1] INFO o.e.k.c.s.r.LogStatusRunnable - Notification LED slow blinking
2018-04-19 12:14:41,725 [qtp8650332-33] WARN o.e.k.w.s.GwtNetworkServiceImpl - Error connecting
org.eclipse.kura.KuraConnectException: "Connection failed. Cannot connect"
at org.eclipse.kura.core.data.transport.mqtt.MqttDataTransport.connect(MqttDataTransport.java:333)
at org.eclipse.kura.core.data.DataServiceImpl.connect(DataServiceImpl.java:493)
at org.eclipse.kura.web.server.GwtStatusServiceImpl.connectDataService(GwtStatusServiceImpl.java:93)
at com.google.gwt.user.server.rpc.RPC.invokeAndEncodeResponse(RPC.java:587)
at com.google.gwt.user.server.rpc.RemoteServiceServlet.processCall(RemoteServiceServlet.java:333)
at com.google.gwt.user.server.rpc.RemoteServiceServlet.processCall(RemoteServiceServlet.java:303)
at com.google.gwt.user.server.rpc.RemoteServiceServlet.processPost(RemoteServiceServlet.java:373)
at com.google.gwt.user.server.rpc.AbstractRemoteServiceServlet.doPost(AbstractRemoteServiceServlet.java:62)
at javax.servlet.http.HttpServlet.service(HttpServlet.java:707)
at org.eclipse.kura.web.server.OsgiRemoteServiceServlet.service(OsgiRemoteServiceServlet.java:41)
at javax.servlet.http.HttpServlet.service(HttpServlet.java:790)
at org.eclipse.equinox.http.servlet.internal.HttpServiceRuntimeImpl$LegacyServlet.service(HttpServiceRuntimeImpl.java:1223)
at org.eclipse.equinox.http.servlet.internal.registration.EndpointRegistration.service(EndpointRegistration.java:148)
at org.eclipse.equinox.http.servlet.internal.servlet.ResponseStateHandler.processRequest(ResponseStateHandler.java:62)
at org.eclipse.equinox.http.servlet.internal.context.DispatchTargets.doDispatch(DispatchTargets.java:131)
at org.eclipse.equinox.http.servlet.internal.servlet.ProxyServlet.service(ProxyServlet.java:74)
at org.eclipse.equinox.http.jetty.internal.HttpServerManager$InternalHttpServiceServlet.service(HttpServerManager.java:284)
at org.eclipse.jetty.servlet.ServletHolder.handle(ServletHolder.java:841)
at org.eclipse.jetty.servlet.ServletHandler.doHandle(ServletHandler.java:535)
at org.eclipse.jetty.server.handler.ScopedHandler.nextHandle(ScopedHandler.java:188)
at org.eclipse.jetty.server.session.SessionHandler.doHandle(SessionHandler.java:1595)
at org.eclipse.jetty.server.handler.ContextHandler.doHandle(ContextHandler.java:1253)
at org.eclipse.jetty.server.handler.ScopedHandler.nextScope(ScopedHandler.java:168)
at org.eclipse.jetty.servlet.ServletHandler.doScope(ServletHandler.java:473)
at org.eclipse.jetty.server.session.SessionHandler.doScope(SessionHandler.java:1564)
at org.eclipse.jetty.server.handler.ScopedHandler.nextScope(ScopedHandler.java:166)
at org.eclipse.jetty.server.handler.ContextHandler.doScope(ContextHandler.java:1155)
at org.eclipse.jetty.server.handler.ScopedHandler.handle(ScopedHandler.java:141)
at org.eclipse.jetty.server.handler.HandlerWrapper.handle(HandlerWrapper.java:132)
at org.eclipse.jetty.server.Server.handle(Server.java:561)
at org.eclipse.jetty.server.HttpChannel.handle(HttpChannel.java:334)
at org.eclipse.jetty.server.HttpConnection.onFillable(HttpConnection.java:251)
at org.eclipse.jetty.io.AbstractConnection$ReadCallback.succeeded(AbstractConnection.java:279)
at org.eclipse.jetty.io.FillInterest.fillable(FillInterest.java:104)
at org.eclipse.jetty.io.ChannelEndPoint$2.run(ChannelEndPoint.java:124)
at org.eclipse.jetty.util.thread.strategy.EatWhatYouKill.doProduce(EatWhatYouKill.java:247)
at org.eclipse.jetty.util.thread.strategy.EatWhatYouKill.produce(EatWhatYouKill.java:140)
at org.eclipse.jetty.util.thread.strategy.EatWhatYouKill.run(EatWhatYouKill.java:131)
at org.eclipse.jetty.util.thread.ReservedThreadExecutor$ReservedThread.run(ReservedThreadExecutor.java:243)
at org.eclipse.jetty.util.thread.QueuedThreadPool.runJob(QueuedThreadPool.java:679)
at org.eclipse.jetty.util.thread.QueuedThreadPool$2.run(QueuedThreadPool.java:597)
Caused by: Not authorized to connect (5)
Any help is appreciated,
Salvo.
FUDForum. Page generated in 0.03484 seconds
